Pics of Boost gauge + turbo timer install
Old Nov 2, 2005 | 08:52 PM
Links0000's Avatar
Had some free time over the weekend and decide to install a few things. Still need to hook up the vacuum line for the boost gauge- that will be this weekend.
Old Nov 2, 2005 | 08:55 PM
Jakeg97's Avatar
looking good
btw - what turbo timer is that?
sirloin1219's Avatar
wow im liking the SSL package on the door
Old Nov 2, 2005 | 08:59 PM
healthynine's Avatar
that's the hks
Originally Posted by burningmoney97
looking good
Links0000's Avatar
Its an HKS type 0 turbo timer
Old Nov 2, 2005 | 10:20 PM
Pianoman90's Avatar
Did you use the supplied tubing with that autometer gauge or did you have to get longer tubing?
Old Nov 3, 2005 | 05:21 AM
Links0000's Avatar
I had to get longer tubing, the supplied tubing is not long enough unless you drill a new hole through the firewall.
Old Nov 3, 2005 | 05:42 AM
4TUN8's Avatar
get some black wire loom from home depot and it will look 100x better. I have the same gauge pod as you in the same location.
Old Nov 3, 2005 | 07:05 AM
sleet's Avatar
Nice picture of the gauge, what camera are you using?
Old Nov 3, 2005 | 07:07 AM
kmcconn9's Avatar
looks good, thats exactly where my boost gauge used to be. I now had a pod. Wire loom is an installers best friend..
TT looks good, I would push the velcro back some so you cant see it from the front. Lokks good though...
Old Nov 3, 2005 | 07:11 AM
forum04pl's Avatar
looks good, and +1 with the black wire loom suggestion
Old Nov 3, 2005 | 07:36 AM
Links0000's Avatar
4TUN8 get some black wire loom from home depot and it will look 100x better. I have the same gauge pod as you in the same location.
Ya I have some wire loom but am waiting till this weekend when I install the vacuum hose to put it on.
sleet Nice picture of the gauge, what camera are you using?
Not sure what camara it is, a friend took the pics.
Old Nov 3, 2005 | 07:41 AM
NocturnalEVO's Avatar
looks nice!
Quick question, does your type-0 turbo timer light up red normally?
And where did you get it from?
Old Nov 3, 2005 | 07:46 AM
Links0000's Avatar
Normally Orange but once it starts countdown it flashes between red and orange. Matches factory dash fairly well.
I actually bought it from a Honda dealership . But you can order them almost anywhere.
Old Nov 4, 2005 | 03:27 PM
4TUN8's Avatar
IMO this was the easiest part of the install, you could probably have it all up and working in 10 minutes.
