whats the best fluid?
Old Nov 9, 2005 | 07:35 PM
brandonbigdog's Avatar
I am ready for my 30k service and was wondering what the best non-oem fluids are for my car. I hear a lot of debate between royal purple and redline, but what gives you the best horsepower and which fluid is used in which part of the car! Thanks!
Old Nov 9, 2005 | 07:44 PM
c kim's Avatar
The most popular ones I've heard around here are bg syncroshift, pennzoil syncromesh, or just the mitsu. diaqueen. As for the diffs, I forget.
Old Nov 9, 2005 | 07:48 PM
eling99's Avatar
i just did the tranny with the redline...im gonna change it again..and try pennzoil or bg!!!
Old Nov 9, 2005 | 07:57 PM
Jin4g63's Avatar
purp
Old Nov 9, 2005 | 08:09 PM
djskyy's Avatar
fluids don't give you horsepower....maybe a little hp gain if you do a oil change or coolant flush before you dyno, that's about it...anyway, I've always had good results on BG or GM syncroshift/syncromesh..
Old Nov 9, 2005 | 08:17 PM
sierrany's Avatar
I just replaced my clutch...Tranny got BG synchroshift and Transfercase got Diaqueen....I did notice that shifting is somewhat smoother...I will try synchromesh next time though
Old Nov 9, 2005 | 08:19 PM
AaronOZ's Avatar
It has to be Royal Purple
Old Nov 9, 2005 | 08:23 PM
ih8emos's Avatar
I have alaways liked redline shockproof light mixed with MTL
Old Nov 9, 2005 | 08:34 PM
Dr. SS's Avatar
i just changed my fluids
mobil 1 10w30 for oil
diaqueen for tc
pennzoil syncromesh for tranny.
much smoother shifts, less tc decel noise. all in all satisfied. and it was easy.
Old Nov 9, 2005 | 10:43 PM
Ivan MR's Avatar
I use Motul.Good stuff.
Old Nov 10, 2005 | 03:47 AM
mdosu's Avatar
just curious, are you racing? What's the incentive to go with non OEM fluids?
I used Diaqueen for the diffs and b/c I couldn't find OEM trans fluid, I went with Syncroshift...I also have Syncromesh sitting on my shelf right now waiting for the next change.
Syncroshift is nice, it's super smooth and got rid of my 2nd gear clunk.
and drivetrain fluids doesn't increase HP...
Old Nov 10, 2005 | 03:51 AM
mdosu's Avatar
by the way you replied, I have to say diaqueen is not recommended in transmission. It's a fluid for the diffs ie: TC, and Rear Diff.
Old Nov 11, 2005 | 12:19 PM
eling99's Avatar
on the pennzoil syncromesh, is there only one kind? cause i went to autozone and it says for like chrysler, or gm! is that the one i should get?
Old Nov 11, 2005 | 12:23 PM
ex-honda's Avatar
You have to think also on your kind of driving. If take your Evo to the track alot, alot of peeps like Redline for all the fluids but for normal driving, stock is just fine.
Old Nov 11, 2005 | 12:31 PM
eling99's Avatar
i have redline and it sucks...so notchy!!! i hate it
