I need power door lock assemblies
Old Nov 19, 2005 | 08:39 AM
gsrboi80's Avatar
Im trying to convert my girls RS to power door locks. I already have the Keyless entry alarm system installed. I need the power doorlock assemblies out of a EVO with power door locks. Its the same Assembly in the RS w/ the connector and everything but in the RS the assembly does not have the actuator in it (but the plug is there I tried to power it but it does not move the lock cable). Any one have these for the doors Ill take all 4
Old Nov 19, 2005 | 09:51 AM
gregb's Avatar
I've seen a few posts where people took the parts from junkyard Lancers with pwr locks and windows. Those parts are not Evo specific.
Old Nov 19, 2005 | 02:19 PM
gsrboi80's Avatar
oh ok I wasnt sure. Just trying to see if anyone on here had any
Old Nov 19, 2005 | 06:31 PM
gsrboi80's Avatar
ttt
Old Nov 19, 2005 | 06:42 PM
taenaive's Avatar
I installed one on my driver side.
you need wiring harness too. RS doesn't have the connectors and wires for the door lock/pwr window. I ran a line from my alram to the door. you can buy from a dealer for 180 dollars( door lock assembly with actuator )
It is funny that you have to get a whole assembly just to get the actuator. and it is pain to install. the black gorilla snot will get everywhere if you are not careful. you gotta have small hands. otherwise, it will be hard to connect those rods.
Old Nov 19, 2005 | 06:47 PM
gsrboi80's Avatar
Had it all apart today I have small hands so it wasnt that bad I wont need the harnesses Ill just run the wires from the Keyless entry Alarm system to the power door lock assembly and solder the connections Itll hold just fine
Old Nov 19, 2005 | 06:49 PM
gsrboi80's Avatar
I was going to try and rig up generic accuators but Itll be real hard to do on an EVO
Old Nov 19, 2005 | 06:54 PM
taenaive's Avatar
let me know if you get those cheaper from somewhere else. I need a passenger side. And I don't feel like paying 180 again. other dealers wanted 220 dollars.
you need to drill a hole for rear doors. I won't do rear doors unless I am really bored.
Old Nov 19, 2005 | 06:57 PM
taenaive's Avatar
yeah, it is not made out of soild rods like other cars. you can do it if you can splice the cable in the middle. However, the rear doors can be easy. those have rods like other cars.
gsrboi80's Avatar
185 each at my local dealer. Somone needs to come up with somthing to allow for keylees entry in a RS thats cheap. Hpfully somone gets back to me on here that has a set at least the drivers side
Old Nov 19, 2005 | 07:00 PM
gsrboi80's Avatar
So mabey ill use those actuators for the rear. Yea I was thinking of cutting open that cable but I was like let me see If I can find somone with the power assemblies
Old Nov 20, 2005 | 05:01 AM
an0ther's Avatar
I did 4 aftermarket DEI actuators in an rs at my work. Have to cut 1 little strip of metal out of the door but they work great. These will save you a ton of money and work great. If your near atl you could come to my shop. We sell the actuators for $15 each and charge $65 to put them in "$80 a door total"
Old Nov 20, 2005 | 05:49 AM
kmcconn9's Avatar
sounds like you work in a roadshop...
Anyway yea the dei actuators are very easy to put in. I myself have installed 4 sets in two different lancers. Very easy and you wont have to worry about cobbling pieces together with junkyard parts..
Old Nov 20, 2005 | 06:57 AM
gsrboi80's Avatar
Anyone feel like doing a write up?
A local shop wants the same price a little steep right now. Mabey you can school me on how you did it.
I really didint want to go hacking away at stuff trying to rig it. But if theres an easy way let me know.
Thanks in advance
Old Nov 20, 2005 | 01:32 PM
gsrboi80's Avatar
bump
