Parts from Japan
Old Nov 25, 2005 | 06:43 PM
akunochi's Avatar
Is that a sequentail shifter? Cause that would be awesome.
Old Nov 25, 2005 | 06:53 PM
Matthew333's Avatar
that is the new design of the ikeya formula sequential shifter- I know because I have it!! 5 SPD only- the lever is a reverse lockout-
Old Nov 25, 2005 | 07:55 PM
talentsearch301's Avatar
Ikeya Formula Sequential Shifter evos 4 thru 8 $1,319.76
Basically it will turn your standard manual transmission into a sequential style gear box without the cost of a new transmission. It is an easy bolt-on modification for the factory installed 5 speed transmissions.
Pulling the lever down results in an upshift, pushing the lever forward results in a downshift. There is a lock-out for reverse, to avoid accidental misshifts.
The shifter comes with an LED monitor, which indicates which gear you are in.
Old Nov 25, 2005 | 08:26 PM
Tsurara's Avatar
Sequental Shifter?
Badass. Not exactly practical, but I admire your guts
Old Nov 25, 2005 | 08:33 PM
Ang Wen Yan's Avatar
Nice!!!
Old Nov 25, 2005 | 11:10 PM
akunochi's Avatar
Where can I order the shifter???
Old Nov 25, 2005 | 11:16 PM
5.slow's Avatar
I am thinking the same thing. That thing is bad ***.
Old Nov 25, 2005 | 11:25 PM
Ichiban's Avatar
Found it for $905 US
http://www.takakaira.com/asp/table.a...&cat=2&prodid=
Old Nov 26, 2005 | 06:48 AM
TOMMY B's Avatar
Matthew333 ,
On a scale of 1- to -10 How well does it work ??
Can you give us a review on it....
Thanks.......
TOMMY B
RALLY ON /////////////
Old Nov 26, 2005 | 07:03 AM
hashiriya's Avatar
Originally Posted by TOMMY B
Matthew333 ,
Thanks.......
TOMMY B
I'd love to see a review as well. cheers.
Old Nov 26, 2005 | 08:43 AM
akunochi's Avatar
+1 on the review...
Old Nov 26, 2005 | 12:06 PM
Matthew333's Avatar
im back-
compared to the factory shifter- 10.
compared to a short shift kit with all bushings replaced, 8....
I have only missed 3 to 4 (total#)shifts since I have installed it- (2nd to 3rd/3rd to 2nd)
Compared to the factory 2nd to 3rd miss or grind- its sweet. There is no way you can screw up or miss-shift if you are rough with the shifter-
Install difficulty: Holy crap, the entire manual is in Japanese- The pictures are good, and I am good with lego's......
Hardest part is you have to install new syncro tens. in the tranny.(battery,tray-out, motor mounts loose/out, motor tilted to put 3 bolts in the tranny)
Adjust by driving around and shifting- find the sweet spot with the cable adjusters, and tighten down.
It is designed for a RHD, so the shifter sits a little to the right-(its ok for me, because I want to convert to rhd anyways)
The height is adjustable on the knob, and gets harder to jam into gear when you adjust it low....
Overall- well worth my money. I can shift through the gears a lot faster without the embarassing rev....plus its just cool. When I drine, its like playing gran turismo with a really good simulator...(FUN) I ordered from taka-kiara(whatever) and had it within 2 weeks...unlike "shellresistant" 8 to 10 weeks????
The shifter is sold without the indicator- The indicator is "universal"- and is for sale further on down the list...
Old Nov 26, 2005 | 12:07 PM
Matthew333's Avatar
I can take some better pics and post (if I can get my cam to take crappy enough pics to fit on the site)
Old Nov 26, 2005 | 12:26 PM
cyberevo8's Avatar
is that the sard tow hook??
vendors plis inform!!
Old Nov 26, 2005 | 12:28 PM
cyberevo8's Avatar
interested were to get the tow hook!!!!!
