Well Its official
Old Nov 30, 2005 | 08:36 PM
sophic's Avatar
Originally Posted by Mercenary3
There are suggestions here. Try what you can. I suggest buying or borrowing a scantool for some of the tests...
Its for a vette, but a lot of the principals apply. Dont know what the correct voltages are though.
P0137 is second 02 sensor, so you are on the right path sophic, as Im sure you already know.
http://gearchatter.com/viewpost14543...1af6f77ba3b0a5
I don't know what to think anymore.
I already have a scan tool.
Old Nov 30, 2005 | 08:57 PM
dubbleugly01's Avatar
Originally Posted by sophic
I thought that the simulator intercepted the signal and changed it before it reaches the ECU. How would this not fix the problem?
someone already tried changing the O2 on there car with the same problems and it still didn't work.
I don't feel like wasting money to find the same thing.
I'm convinced it is a computer problem.
First off, what mods do you have? Are you running a cat or not? It's hard to tell, because you said you put in a new cat, yet you also have an 02 cel fix installed?
Either way, if you put in the 02 cel fix, it sounds like you didn't get the wiring correct. Who's instructions did you use to install the 02 cel fix?
Look at the attached thumb, it might help.
Old Dec 1, 2005 | 05:48 AM
sophic's Avatar
I am running a high flow cat, but running cat or not the SIM should intercept the signal and change it before it reaches the ECU.
White/black wire going toward ECU.
White wire going to O2.
It's installed correcty.
Old Dec 1, 2005 | 05:55 AM
MM Racing's Avatar
I am not completely familiar with that perticular code but from the sounds of it I am thinking the heater circuit is fried in the sensor and if that is the case then the mechanical nor electrical fix will take care of it. Take the sensor out and measure the resistance across the heater coil and compare to the spec.
SloRice
For Sale - Cars For Sale
47
Oct 18, 2010 10:33 PM
Gruppe-S
Evo 'For Sale' Interior Styling
69
May 6, 2009 01:42 PM
Gruppe-S
Evo 'For Sale' Wheels / Tires
71
Apr 21, 2009 03:58 PM
PHILLY EVO
10
Apr 30, 2006 08:02 PM
BennettOZ
Nov 14, 2004 06:21 AM
