Slim Fan Question
Old Dec 6, 2005 | 06:20 PM
TheBigLubinsky's Avatar
Slim Fan Question
I need a slim fan for my engine bay. I purchased one used, but it is the fan on the front side of the Koyo. I need the one inside the engine bay b/c my intercooler pipes are rubbing against the fan blades really bad. Thanks.
Old Dec 6, 2005 | 07:07 PM
ih8emos's Avatar
I think most fans you can turn the blades around the other way. just pop the little clip out
Old Dec 6, 2005 | 07:15 PM
LEADING EDGE's Avatar
Spahl makes a good one1
Old Dec 6, 2005 | 07:30 PM
w_tomas's Avatar
If what I'm reading is correct...you bought a slimline fan configured to be a push type fan, when you need it to be a pull type(behind the radiator). With mine, I pulled the fan out by removing the nut on the center of the fan and turned the fan over. The instructions I had also said to reverse the polarity and that was it. good luck.
Old Dec 7, 2005 | 03:40 PM
It has nothing to do with the direction. The fan housing is too wide and when the fan turns on, the blades are rubbing against the UICP.
