redlined the ix..
Old Dec 7, 2005 | 11:59 AM
Jakeg97's Avatar
Originally Posted by diiirk
im gonna take that gauge out...its definatly not right...when the car first starts it sits at zero for like 15 seconds...then drops down to vac..
something def wrong ^^
Old Dec 7, 2005 | 12:02 PM
ErroR's Avatar
I agree my car is having serious issues. I brought the car in for low boost and they stated the timing was off by 5 degrees. After resetting the timing to factory spec my car sounds like it has a damn supercharger in it and still doesn't boost past 1.3 bar.
sorry for the thread jack
Old Dec 7, 2005 | 02:06 PM
diiirk@AwdMotorsports's Avatar
how many miles did u other ix guys put on the car before realy driving it....i been babying mine up to the 500 it has now....today was the first time i took over 5k..but i dont kno how many more miles i should put on it until i change my oil and start really drivin it...
Old Dec 7, 2005 | 02:16 PM
ErroR's Avatar
3000 rpm for first 350 miles, 3500 rpm to 500 miles, 4000rpm to 600 miles, 4500 rpm to 700 miles etc.........
first oil change at 1000 miles and I will be getting my second oil change and harassing the dealer again this weekend at 3000 miles.
Old Dec 7, 2005 | 02:28 PM
Warrtalon's Avatar
dirrk, your car is ready. YOu only need to go 600 miles without going over 5k rpm too often. After that point, go buck wild. I didn't change my oil until I was supposed to, which was around 4500 miles...not 1k, not 2k, not 3k...almost 5k like the manual says to do on synthetic oil.
Old Dec 7, 2005 | 02:34 PM
lil'evil_evo's Avatar
I thought I was the only one everyone seems to really baby these cars after the real break in period
Old Dec 7, 2005 | 03:16 PM
fusionchicken's Avatar
Originally Posted by zzombae
My evo still under 400 miles on it...AAAHHHHHHH hard to wait~! I have to drive more...I almost forgot that my evo has turbo..
dawg, let me help you with the break in !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 7, 2005 | 03:58 PM
an0ther's Avatar
my ix peaks at 1.5 and tapers to 1.2 so about 22.5psi to 18psi. Its a defi BF gauge so i know its accurate.
Old Dec 7, 2005 | 04:06 PM
housedj's Avatar
Thumbs up
yup i ran both cars slow up to 1K miles, then immediately changed to Royal Purple. I also used Royal Purple Max-Gear oil (75w90 @$10/quart) in the diffs & T/C @ 5K miles & my '03 no longer misses 2nd gear. for the record, the '05 never missed 2nd gear. for the price of 1 can of mitsu diaqueen LSD fluid ($84), i got enuff royal purple max gear oil to do 2 EVO's front to back!!
& just so everyone knows, all stock unflashed EVO fuel cuts are set at 7404 RPM, not 7K, not 7600.
Old Dec 7, 2005 | 04:07 PM
yea i need to get a good set of gauges...i want to go with a triple gauge a pillar...boost gauge, a/f gauge and i dunno about the 3rd gauge....i dont want to spend to much money on gauges tho..
Old Dec 7, 2005 | 04:10 PM
DRAGIN's Avatar
500 miles of easy around town type driving to break in the clutch. The motors break in very quickly so dont' worry to much about that. After that go have fun and drive it like ya stole it. j/k
Old Dec 7, 2005 | 04:21 PM
SilverNine's Avatar
hey diirk where in laurdedale are u located, i have yet to see a nine on the streets, barely any Evo's around here, only the same ones all the time.
Old Dec 7, 2005 | 07:01 PM
el producto's Avatar
lol yeah when I first time got my 05 I didnt bring it past 5k for break in but i floored it from 0 to 5k and I couldn't imagine the pull it had and wondered what it would be like to get past the 5k to 7500 but when breakin was finally over and tried it there was not much more pull left in her. Soon your evo will feel slower after a few thousand miles because your use to its power and you'll wanna make her faster.
Old Dec 7, 2005 | 07:26 PM
Warrtalon's Avatar
What? Stock, unflashed Evo fuel cut? Fuel cut has nothing to do with RPM; it is caused by too much airflow. If you're trying to say that the stock rev limiter is at 7400, that's not true either. It's at 7600, which is common knowledge.
Lastly, I hope no one else goes through all that trouble for 1000 miles, because not only is it boring, it's not the proper break-in procedure. You actually NEED to drive it somewhat hard in the first 500 miles, but just not rag it out to redline. After 500-600, it can be thrashed without hesitation (and likely well before then).
Old Dec 7, 2005 | 09:24 PM
steadfast's Avatar
I have been driving my car like i would if i never knew of a break-in period. Accelerating hard from time to time We'll see how it goes. I'd like to have it dynoed but the closest all wheel is a couple hours away.
