Vishnu Evo Web Site Update
Old Mar 24, 2003 | 03:01 PM
  #31
ShapeGSX's Avatar
Originally posted by shiv@vishnu
It doesn't. I promise.
So I guess you just modify the inputs to the ECU that would affect the injector duty cycle?
Like an AFC does, but with a larger, 3D map (boost vs RPM with a Z axis of correction)?
Old Mar 24, 2003 | 04:10 PM
  #32
Shahul X's Avatar
wow, too bad you Cali boys cant go to the gas station and get 94 octane like us east coasters lol.... just kidding...
Shiv where are you from and guessing your Hindu with "VISHNU" as your company name
-Shahul
Old Mar 24, 2003 | 04:19 PM
  #33
ShapeGSX's Avatar
I found info on the Xede:
http://www.chiptorque.com/105848.php
It looks to be somewhat akin to an AFC with multiple maps that are switched to based on boost pressure (or some other user definable input). Hopefully it also interpolates between the maps. All it does is modify the input MAF signal just like an AFC. It does look like it has a lot of user-definable ways to do this, though.
Timing can also be modified with the xede.
However, just by changing the MAF signal, you will end up changing the timing output of the ECU.
If this works well on the Evo, then I stand by my statement that an AFC should also work quite well on an Evo.
Old Mar 24, 2003 | 04:45 PM
  #34
Max Rebo's Avatar
Originally posted by silvrevo
Shiv I know you said most boost for production cars. Didnt the sabb viggen make 22psi? I know its not in production anymore , but that is alot of boost. What other production turbos make that kind of boost from the factory?
Thanks for all your time and imput.
That sounds about right, IIRC. We owned A Viggen for a couple years, but never tuned it beyone factory spec. 20+ psi is the highest I've heard. It exhibited plenty of torque steer, too.
My beef with that car is that it had a torque limiter (set too low) in 1st & 2nd gears, not to mention 1st gear was incredibly short. Once you got into 3rd gear, though, it was a rocket, and surprised many people. Those front seats were mighty comfy, too.
Old Mar 24, 2003 | 04:51 PM
  #35
Max Rebo's Avatar
Just some info to chew on. I'm sure it will be rejected and projectile vomited by a few
Cheers
Shiv S. Pathak
Engine Calibrator and Owner
Vishnu Performance Systems
That's fantastic! Funniest thing I've read all day...
The thing is... you're probably right on target with that comment!
Old Mar 24, 2003 | 06:24 PM
  #36
twdorris's Avatar
Originally posted by ShapeGSX Like an AFC does, but with a larger, 3D map (boost vs RPM with a Z axis of correction)?
Yeah, looks like an AFC on steroids or a stripped down PMS. What are these units selling for? It outta work on just about anything I would imagine. Not too shabby of a toy I suppose; it's actually kinda neat if you're into the piggy back thing.
No injector drivers because it's faking the ECU airflow signal. Unless it also includes a knock read out somewhere that I missed, then it's probably difficult to tell if the resulting ECU ignition advance is straight from the tables or altered due to knock. Still, not terrible, assuming the cost is inline with an AFC.
Thomas Dorris
Old Mar 24, 2003 | 09:27 PM
  #37
shiv@vishnu's Avatar
Thomas Dorris
It will be priced competitively considering its performance. That is, somewhere between the DSMLink and the Autronic PnP. It's not really fair to compare it to an AFC which offers relatively low resolution, no real logging abilities, limited flexibility, no multiple map storage and oh yeah, no timing control. The next firmware revision of our EVO XEDE will also offer closed-loop boost control. So one would have to compare it to an S-AFC + ITC + AVCR in order to have all the basic bases covered.
Cheers,
Shiv
Old Mar 25, 2003 | 12:40 AM
  #38
-Shahul
I'm hesitant to give any personal info since a few of the villagers on this forum may find a way to use it against me
Cheers,
shiv
Old Mar 25, 2003 | 08:29 AM
  #39
ShapeGSX's Avatar
I was only comparing it with the AFC in terms of what it ultimately does for fuel control, which is modify the MAF signal.
PERRIN_JOHN
Northwest Region
27
Dec 30, 2007 11:25 PM
sportmitsubishi
Southeast Region
Jan 25, 2007 11:38 AM
smc20g
10
Sep 10, 2004 11:12 AM
doc_evo
Northeast Region
80
Oct 24, 2003 01:59 PM
