Dealership SAYS Downpipe problem!
Old Dec 7, 2005 | 06:35 PM
alby988's Avatar
Question Dealership SAYS Downpipe problem!
whenever i went over bumps, cracks, or whatever, i heard squeaking coming from the front and back . i thought it was something in my suspension due to potholes or something so i took it to the dealership to see what was causing the squeaking. i have a works 3" downpipe, works 3" high flow cat, and a rnr 3 " catback. the dealership said that it wasn't my suspension but my downpipe making the noise . he said since i dont have a flex section on the downpipe it moves and causes squeaking. can this be true ? please help me.
is there anything i can do to fix it?
also,
are there any ways to check to see if its actually my suspension thats making the noise or not?
thanks in advance,
albert
Old Dec 7, 2005 | 06:43 PM
Sackett's Avatar
Yeah, have you ever seen those commercials, i forget which company it was for, but there is a technician holding onto the bottom of the car looking for the problem while the guy is driving around.. thats one way. Just find a friend of yours who is into cheap thrills.
On a more realistic approach, and using common sense,
1. take off your downpipe and see if it goes away (lightbulb!)
2. Check underneath and see if it is moving or rubbing on anything (undertray, tie bars, frame, etc.)
3. Kartboy stiff exhaust hangers.
Old Dec 7, 2005 | 06:53 PM
Impulsoren's Avatar
The stock downpipe doesn't have a flex section either. If your downpipe uses the stock donut gasket at the O2 housing that is all the flex it needs.
Old Dec 7, 2005 | 06:54 PM
twinturbozs's Avatar
Im sure on acceleration, the engine torques a bit too.
Old Dec 7, 2005 | 07:02 PM
BoostWhore's Avatar
the factory dp doesnt have a flex section it pivots on the donut gasket the same way as the works..... maybe its rattling on the tie bars
Old Dec 7, 2005 | 07:09 PM
alby988's Avatar
i have kartboy exhaust hangars in use and it squekas even at low speeds over little bumps
Old Dec 7, 2005 | 07:16 PM
jonpfive's Avatar
try squirtimg some lube on the hangers. I recommend HHS 2000 by Wurth because not only does it resist water, but it sprays as a liquid and then sets up into a grease so it penetrates into cracks very well.
Old Dec 7, 2005 | 08:08 PM
alby988's Avatar
i dont want to have to sell my downpipe
Old Dec 10, 2005 | 06:48 PM
alby988's Avatar
bump?
Old Dec 10, 2005 | 07:03 PM
stevo_mr's Avatar
Grease all your hangars for exhaust like previous post. Make sure all the rubber hangars aren't being stretched. The exhaust hangars should be pretty neutral in the holes. If they are to the sides or stretching it down this could cause squeaks. Check for any interference as previous post also. For suspension if you are still stock I would personnally say it is not them unless there is some misalignment (not wheel alignment) of your suspension arms or something loose. If it persists have the dealer check all tourques on the suspension. I am a Noise and Vibration engineer and this is what I would do. Some squeaks come from weird areas and are difficult to isolate are you sure it is from underneath your car?
Old Dec 10, 2005 | 08:23 PM
alby988's Avatar
yes im sure its coming from underneath the car, and i am currently using kartboy exhaust hangars
Old Dec 11, 2005 | 10:21 PM
stevo_mr's Avatar
Explain Kartboy hangars is the rubber stiffer, do they hang lower, higher, or make the exhaust hang from different locations? Are they solid mounts?
Old Dec 11, 2005 | 11:08 PM
voidhawk's Avatar
they are stiffer - polyurethane instead of rubber.
Old Dec 12, 2005 | 12:00 AM
simevo's Avatar
polyurethanes are horrible without proper lube. Go get some lubes for the polyurethane (very thick and sticky lube).
Old Dec 12, 2005 | 04:12 AM
alby988's Avatar
any suggestion on what kind of lube
