Installed Defi BF boost gauge, hints & questions
Old Dec 13, 2005 | 06:06 AM
an0ther's Avatar
congrats, i have the same gauge. You should hook up your illum wire for sure. When the illum is powered it dims even lower than you can turn it down on the unit itself and doesnt blind you at night. That gauge is right on the money and should not be off more than 1/2 psi. Heres a pic of mine!
Old Dec 13, 2005 | 02:31 PM
ksattic's Avatar
Aight, pics going up when I get back from work... I'll also show off my neat Sirius install.
So, given those specs for the VIII and the Defi (admittedly I've not even checked the Defi manual yet for any official figures), my Evo is either boosting a touch too high or my sender is off. I doubt the gauge is at fault at all, since it's a stepper motor.
an0ther: what hose did you tee your sender to?
Old Dec 13, 2005 | 02:39 PM
GinuwineEvo8's Avatar
Your car is fine ... 03-04 evos go 20 taper to 17 ... 05's peak higher because of the bigger hotside ...
Old Dec 13, 2005 | 03:42 PM
Djstorm100's Avatar
06 (evo 9's have the bigger hot side) i thought
Old Dec 13, 2005 | 06:27 PM
Sackett's Avatar
05 and 06 have the same size hotsite. something is different on the turbo, but the hotside is the same size
Old Dec 14, 2005 | 07:24 PM
ksattic's Avatar
Defi BF and Sirius install pics
Here are pics, as promised, a day late.
Daytime:
Nighttime:
Illumination off:
Control Unit II:
Turbo hose tee:
Sender unit:
Mounting location:
Head unit and Control Unit II:
Sirius antenna on world's dirtiest TB Evo:
I live in a new housing development and they leave piles of mud in the road that get all over. One day after washing and waxing my car, it was so filthy that people were asking where I do Auto X.
Old Dec 14, 2005 | 10:08 PM
Lazyfong's Avatar
I see you mounted the T connector to a different line, the gauge looks nice!
Old Dec 15, 2005 | 07:52 AM
ksattic's Avatar
Thanks, I love the gauge!
What do you mean by different line - different to what? I followed the instructions supplied with the Defi gauge, which match the ones at the features section of this website.
Old Dec 15, 2005 | 12:12 PM
Lazyfong's Avatar
Some people say it is better to put the T into the line that is circled in the picture.
Old Dec 17, 2005 | 04:34 AM
dakind916's Avatar
Nice set up. Mine was a little different though. I put the guage closer to the left on the dashboard, so the line looks cleaner. I also zipped tied the lines in the engine bay to make it look cleaner. Lastly, I wonder if it really matters where u t-off the boost line. I did it right off the FPR according to the "how to install" thread; regarding installing a boost guage.
Old Dec 17, 2005 | 04:45 AM
an0ther's Avatar
lazy, i have no clue why that install guide says to tap there. If you look in the instructions of any boost gauge, they say to tap it at the end of the rail like he did. Thats how I have mine and have had mine on all my turbo cars.
Old Dec 17, 2005 | 11:26 AM
Lazyfong's Avatar
I saw couple tutorials and ask some other people, they said it was just better at that location. Cause I seen people tap at both locations so I was not sure as well.
Old Dec 17, 2005 | 11:33 AM
Evoryder's Avatar
he tapped into the correct line....right off the fuel pressure regulator...best results there.
i want a defi gauge! wah wah wah ..not sure bout that mounting spot
Old Dec 17, 2005 | 11:55 AM
Hotshot940's Avatar
where did you get a defi BF that measures psi instead of bar? I havn't been able to find any that didn't read bar.
Old Dec 17, 2005 | 12:03 PM
Evoryder's Avatar
defi-shop.com just started making/stocking them as of august 05
http://www.defi-shop.com/product/bf/bf_type.html
