Installed Defi BF boost gauge, hints & questions
My Defi BF boost gauge arrived this week so I installed it and the control unit this weekend. The install went well, although I have got the following hints:
My '05 Evo VIII is completely stock aside from a WORKS drop-in air filter, and the Defi BF is reading exactly 22 psi peak and it holds 18 psi after it tapers off. The meter reads exactly 0 when the engine is off. Is it possible the meter is off? Would anyone happen to know the margin of error on the Defi BF boost gauge and the specs I have seen quoted for the Evo VIII on this site (20-ish psi peak, tapering to 17 psi)?
I am tapped into the hose as suggested by the article in the features section of this site:
https://www.evolutionm.net/features/...rojectevo/24/3
The gauge looks very nice - I mounted it above the instrument cluster to the left so it doesn't block any of the factory gauges.
- The tutorial in the "features" section of this website mentions removing a rubber bung in the firewall. It pushes in from the engine side to the cabin much easier than it pulls out and will fall out neatly in the passenger footwell.
- You can tap all connections into the radio harness, including the illumination wire, although it will not dim with the other interior lights. I didn't find getting a dimming illumination wire necessary as the Defi BF has 5 levels of illumination when the lights are on and off. You can have them set to bright for day (lights off) and dim for night to match the main cluster (lights on).
the grommit or however you spell it is easy to push back in once you get it out, i lubed it with some lithium grease and it slid in really easy. pulling it out ? ... not so easy...i end up stabbing it with a hook tool i have and it came out. unfortunately i have rather large forearms so i could barely fit in the gap i had to work with
Originally Posted by walkedu
Why would you push the rubber piece into the engine bay in the 1st place? I've never heard of anyone doing it that way?
Anyone know the margins of error expected for Defi BF gauges or the specs quotes for the Evo VIII stock boost?
If not, I'll try contacting Defi.
Originally Posted by ksattic
I wasn't trying to push it into the engine bay, I was trying to pull it out. Took me a minute before I realised it pushed into the passenger compartment very easily.
If not, I'll try contacting Defi.Trending Topics
I thought since it has its on senor it would be very accurate.. unlike mech. ones? but when hooking up the sending try to make the vaccum line close as possblie to the source, to the sender unit it self
if u pushed the gromet in the car and lost it, chances are, it went behind the plastic kickplate thing. if u pull off the plastic door sill, and kinda pull it back, the gromet will just kinda roll out in front of you. that happened to me. ill try and post a pic.
If not, I'll try contacting Defi.Boost Press (WOT/3500) 20.31 psi
Boost Press (WOT/6500) 17.40 psi
