Help With Oil Pressure
Old Dec 13, 2005 | 04:32 PM
dEdiYT11's Avatar
Hello,
I have a Defi Oil Pressure Gauge that has been working fine for about 3 months and yesterday the readings from the gauge are much lower and today it is reading 0. Is this a bad gauge, clogged sensor, or is my oil pump going out? How do you tell if the oil pump is dead?
Any help is greatly appreciated
Chris
Old Dec 13, 2005 | 04:49 PM
Bluesmaster's Avatar
I just had something similar happen with my Defi oil pressure gauge, although my gauge never read zero. Mine would go to one spot and never move. It was bad wiring/sensor. Once that was replaced everything went back to normal. Mine was heat damaged so I wrapped the new one with some shielding. Hopefully that will keep it from happening again. I believe you would get an idiot light if oil pressure failed completely, but I'm not sure.
