Lost APS bov adjustment bolt
Old Dec 14, 2005 | 12:54 PM
jesterEVO's Avatar
Yeah i lost it. I was adjusting it and i guess i went to far and it fell off going down the road! Anyone with a APS bov can you check the size of the bolt and get a height measurement of the bolt? It shouldn't be that thick. I think the size might be 8mm not sure. Just want to know before heading to autozone of somethign...
Old Dec 14, 2005 | 01:46 PM
jesterEVO's Avatar
bump
Old Dec 14, 2005 | 01:49 PM
RallySport Direct's Avatar
Silver Sponsor
WRONG SPEC
Ben
Old Dec 14, 2005 | 01:56 PM
Silver Sponsor
You know what I looked at the wrong spec. Let me find you the correct size and I will post it.
Ben
MitsuEvoIIX's Avatar
you shouldnt have been adjusting it anyway it comes pre adjusted for the evo
Old Dec 14, 2005 | 02:04 PM
Silver Sponsor
You know i cannot find the exact spec. I had it here the other day but lost it. Let me talk to APS tonight and I will get back to you
If I remember right it is 12mm 1.25 but don't quote me on it
Ben
Old Dec 14, 2005 | 02:08 PM
jesterEVO's Avatar
ok cool pm me when you do
Old Dec 14, 2005 | 02:45 PM
accident's Avatar
m8x1.25
Old Dec 14, 2005 | 04:22 PM
Silver Sponsor
exact spec from APS 8 x 1.25 x 20mm stainless steel grub screw
Ben
Old Dec 14, 2005 | 04:28 PM
jesterEVO's Avatar
thank ben!
Old Dec 14, 2005 | 04:35 PM
Silver Sponsor
Anytime!!
Let me know if you have problems tracking down the correct bolt.
Make sure you get something that you can lock the adjustment down and use a stainless bolt to prevent galling of the threads.
Ben
Old Dec 14, 2005 | 04:54 PM
dubbleugly01's Avatar
I doubt autozone will carry the exact bolt, with the allen head adjustment capabilities. They may carry a plain stud in the right dimensions, but I'd go a bit longer, because you'll either end up double nutting it, or worse, putting a pair of channel locks on the end of the bolt to screw it in/out. Going a bit longer will give you room to do what you need to do (get it adjusted right) if it doesn't have the allen head adjustment machined in.
Old Dec 14, 2005 | 04:58 PM
Silver Sponsor
Well the way I would recommend getting it perfect is to buy a long bolt cut it to length dremel a flat head screw into the top and then get a nut to lock it in.
Ben
Old Dec 14, 2005 | 10:29 PM
jesterEVO's Avatar
lol the bolt didnt fall out the adjustment screw did..lol..did i make a mistake typing? yeah i found the washer in the engine bay..the bolt screw was lost...:-p 8 x 1.25 x 20mm <----guess find a bolt screw to fit that?
Old Dec 15, 2005 | 09:06 AM
Silver Sponsor
I am kinda lost here.
That spec is for the adjustment nut with the hex key in the head of it. If you lost the locking nut just buy one with that is size 8x1.25 stainless
Ben
