Megan DP: to heat wrap? and nuts torque
Old Dec 15, 2005 | 07:21 AM
mayhem's Avatar
Originally Posted by Fa$[- a$ $hi[-
If you're going to respond to a post, have respect for people.
If your oil is hot, it will have more pressure, which will cause the oil light to come on. The oil light is designed to sense oil pressure, either high or low, not oil level (that's what a dipstick is for). it doesn't work like a gas gage sensing the level.
I meant Oil being too low causing the low pressure switch to go off. Yeah, the oil warning light is based off of pressure. I'll give you that and what I said made it sound like it was based off of level, not pressure. That's my fault. But I still find temperature having little to do with the pressure in the oil system.
I don't see how I was being disrespectful. Just because I don't feel like typing out your cra$[*y] a$z user name makes me disrespectful?
Old Dec 15, 2005 | 07:30 AM
bigfishs's Avatar
Thanks
Originally Posted by mayhem
Bigfish,
The OEM spring bolts call for 37 ft-lbs. I know that doesn't help, but it sounds like you're in the right ballpark.
Old Dec 15, 2005 | 07:33 AM
dubbleugly01's Avatar
I wrapped my dp becasue it was very close to the oil pan. If you autocross or drive in boost for any extended period, I could see how unwanted heat could be tranferred to the oil pan and the oil. But like previously mentioned, it isn't needed, just and extra level of safety.
See if you can find a bad 02 sensor at a local shop that has been thrown away. You can screw that in to plug your hole. Probably for free.
hot (within the range we are interested in below say 300 F) oil will not have more pressure, or at least more measurable pressure. First, the crankcase vent will keep things in check. Secondly, the vapor pressure of oil is very high, and doesn't change measurably at these temperatures. Bigfishs, you got my back on that last statement?
Old Dec 15, 2005 | 07:43 AM
bigfishs's Avatar
[QUOTE=dubbleugly01Secondly, the vapor pressure of oil is very high, and doesn't change measurably at these temperatures. Bigfishs, you got my back on that last statement? [/QUOTE]
Vapor pressure of oil really only gets high when you get close to its boiling point. Dont know what the boiling point of 5W30 is, but I'd be surprised if it was much below 500F
Old Dec 15, 2005 | 07:49 AM
bigfishs's Avatar
Originally Posted by dubbleugly01
the vapor pressure of oil is very high, }
Actually the VP of oil will be low, as it has a high boiling point. If you heat it until it boils, then VP raises until it =atmospheric pressure
BTW I am an synthetic organic/medicinal chemist , and this stuff is physical chemistry
Old Dec 15, 2005 | 07:54 AM
walkedu's Avatar
Originally Posted by bigfishs
Couple of questions about my Megan TBE install I just completed
Do I need to heat wrap the downpipe near the turbo to protect the surrounding area from heat? ( I am aware of doing it to increase performance, but dont care about that). Its not touching anything.
Any idea of a good torque to use to hold the DP to the turbo O2 housing, using normal bolts (not the OEM ones with springs couldnt seem to get them in)?
I went to around 45ftlbs and they felt pretty tight at that, no leaks. The DP has a flex section in it.
Anybuddy sell the o2 bung screw caps? Mine departed the testpipe at around 80 mph on the highway as I forgot to tighten it. I tried to get an 18 mm spark plug to plug it, but cant get one locally. I am making a makeshift one up by having the end of a spark plug antiflouler welded shut.
I know an M18 x 1.5 bolt will do it, but you have to special order them, like the spark plugs.
Aside from a few fitment issues I love the Megan TBE . Talk about a difference on going from stock exhaust to full TBE
I have a Megan DP as well. I couldn't get it to fit right for about an hour. Then my buddy walkes over and tears the stock metal braided O-ring off the 02 housing. Since my Megan DP came with a built in O-ring (yours might have too... Gold tin foil is what it looked like), i wasn't aware that i needed to remove the stock one. After that, the DP slid on like a champ allowing me to use the stock bolts with springs. No leaks, no issues, and bolts are still held tight as stock. Hope that helps you?
Old Dec 15, 2005 | 08:09 AM
bigfishs's Avatar
yeah I removed the old one. I couldnt get the spring ones started for some reason, and Zeus said to use the hardware suppilied. It doesnt leak, I just didnt want to overtighten the bolts.
Old Dec 15, 2005 | 08:10 AM
Cali2MDevo8's Avatar
Registered User
Bigfishs
Hey, how do you like the megan TBE? I was thinking of purchasing a TBE after the holidays. I have a child and don't want it too loud. I have a full exhaust on my civic and am planning on removing it for loudness issues.
Give me your opinion. Thanks.
Old Dec 15, 2005 | 08:18 AM
bigfishs's Avatar
If you leave the plug in the mullfer it is really quiet (but you are cutting your hole down to maybe 2 inches at the end), like stock.
Take it out and it is definitely louder at idle, and a bit of drone at 3.5K. Not really that loud at WOT, I have heard many louder fart cans
I plan to leave the silencer bit in to get better gas mileage until the end of winter. I will leave it in for long highway journeys.
Then when its racing time, take it out. It comes out with a 10 mm spanner and alan key in 2 mins.
The system feels like it makes great power. Ist and 2nd gear are nuts with just a flash and TBE
In summer when I want to
Old Dec 15, 2005 | 08:24 AM
Kee1pride's Avatar
I never knew you were a chemist.
Old Dec 15, 2005 | 08:49 AM
Registered User
Thanks!
My goal is to just make 300 whp. No flaming......i know different dyno's make different hp and ET times are better. Just a personal goal of mine. I'm stock right now, but want to leave it that way until i get some more milage on it. Just don't want any warranty issues until i know everything is working well. Only have 2700 miles on it now.
Old Dec 15, 2005 | 08:51 AM
[QUOTE=bigfishs]
Originally Posted by dubbleugly01Secondly, the vapor pressure of oil is very high, and doesn't change measurably at these temperatures. Bigfishs, you got my back on that last statement? {thumbup}[/QUOTE
yeah, yeah..... I knew what I meant! lol, it ain't very volatile! ChE here, loving every minute of it to.
Old Dec 15, 2005 | 08:55 AM
walkedu's Avatar
I went with my Megan DP to a straight pipe with my stock tip welded on to the end. No cat, no muffler, no nothing.. Just straight 3" pipe all the way back as if it were a really long Down Pipe. Sounds mean as hell! Only cost me $55 bucks mounted and madrel bent with flanges too!
Old Jun 20, 2006 | 01:20 PM
DingDong02's Avatar
It seems only stupid questions are answered here in this forum, like
"how can I make the psssh sound"
"can I run my car on 87 octane"
"how do I make my evo RWD for a 2f2f parody"
I give up. I know I posted it in the wrong place, hence the link in the right place, but have all the really smart people gone home forever?
I tried the megan website, and th megan thread, and the search revealed way too many unambiguous hits.
Dafarmer, warrtalon, gregg, blonde, timbitz?anyone?
Are those questions really that stupid and have been answered loads of times?
wow what a tool! People like you make good sites like this ****ty!
Old Jun 20, 2006 | 06:35 PM
Kee1pride's Avatar
bigfishes is a friend of mine and certianly not a tool. people like you who sit around searching for threads, that are dead, for something to b*tch about are tools.
