broken valve cover...is it dangerous?
Old Dec 14, 2005 | 09:41 PM
Thoe99's Avatar
I was installing my ingall's stiffy damper tonight and noticed that my black plastic valve cover is cracked over one of the screws, like it was overtorqued. Oddly, no one has ever unscrewed it before. How bad is this? What causes this? Will this be covered under warranty?
Old Dec 14, 2005 | 09:44 PM
WrX Kila's Avatar
get it changed soon. May leak oil
Old Dec 14, 2005 | 09:48 PM
keviin's Avatar
you mean the one that says mitsubishi.. that isn't a problem if it's cracked..
Old Dec 14, 2005 | 09:50 PM
taenaive's Avatar
black plastic valve cover?
The valve cover for evo is red and made out of aluminum. Are you talking about the black spark plug cover with mitsu logo? if it is the spark plug cover, it is okay but you should take that out and see if the red valve cover is cracked also.
Old Dec 14, 2005 | 10:21 PM
P_A_STREET_EVO8's Avatar
OMG dude are you for real with this post. Its the spark plug cover man it dont matter if its cracked get a new one they cost about 40 bucks at the dealer
Old Dec 14, 2005 | 11:08 PM
Derek Baker's Avatar
The valve cover is made out of Magnesium.
Old Dec 14, 2005 | 11:16 PM
Hotshot940's Avatar
that black plastic valve cover being cracked is no big deal. my only concern would be getting water to seep down into there and end up chillin with your spark plugs, then your going to be misfiring and crossfiring like a mother. i wouldn't worry about it tho.
Old Dec 15, 2005 | 01:38 AM
fromWRXtoEVO's Avatar
My MR valve cover is made of a different metal other than aluminium, I think is called molebnium or something like that. It has the initials MB on it.
Old Dec 15, 2005 | 01:40 AM
I don't trhink you broke the valve cover . I saw the other day one Evo getting a engine damper and it is installed where the cam cover goes. You probably are mistaking between the cam cover and the valve cover.l
Old Dec 15, 2005 | 01:55 AM
Killboy's Avatar
It's Magnesium, it's not just the on the MR, and the Periodic Symbol is "Mg". It's a fairly rare metal with high strength to weight properties and the noteriety of burning furiously with enough heat.
Molybnium is a type of grease.
Old Dec 15, 2005 | 04:43 AM
Thoe99's Avatar
My bad, it is the spark plug cover. Phew, you guys made me feel a lot better though.
Old Dec 16, 2005 | 10:16 PM
timzcat's Avatar
There is a drain for that area generally there for spilled oil to drain out but it works for water too.
Old Dec 16, 2005 | 10:23 PM
timzcat's Avatar
Just to be clear.
It is a cam cover not a valve cover. That really is not the right terminology because it covers the cams not the valves. I hate when terms are improperly used, it only causes more confusion. And while I am on the subject it is a rocker cover on pushrod engines.
Don't get me started there are plenty of these, like alternators. (no such thing!)
Old Mar 12, 2006 | 06:24 AM
Nesiop's Avatar
Bringing this thread back to life, last night I was retorqing my cam gears, and when I was tightening it by hand one of the back bolts cracked the cover, it is a tiny tiny crack but still.
Where can I buy a new one?
Old Mar 12, 2006 | 07:19 AM
Evoryder's Avatar
get a clear one from lancershop...and use the 2 finger method when tightening panels and stuff
