DC Sports Manifold
Old Dec 16, 2005 | 05:50 AM
S-1's Avatar
S-1
DC Sports Manifold Concern
I just received my DC Sports manifold and noticed that the Turbo Inlet flange has cracks on the inside of the manifold. Is this something to be concerned about or will the flange hold??
Thanks
Old Dec 16, 2005 | 06:02 AM
honda-guy's Avatar
that's just the seam between the runners and the flange, as long as the welds look good on the outside it should be ok.
Old Dec 16, 2005 | 07:21 AM
S-1's Avatar
S-1
yeah the welds are fine, actually quite nice on the outside. i'm just not sure that after a few years the flange will begin to crack? oh well, i guess time will tell?
thanks
Old Dec 16, 2005 | 09:16 AM
RogueSTi's Avatar
Wow. I would have assumed that DC Sports would have welded that seam inside the flange as well as outside. Usually, DC Sports have great products.
Old Dec 16, 2005 | 09:19 AM
CArkid0101's Avatar
how much did u get it for? let us know how it installs, and how it runs after installed as honda guy said if the welds are good on the outside you should be ok
Old Dec 16, 2005 | 09:38 AM
EVIL EVO 8's Avatar
You Would Not Be Able To Buff Off The Bead Splatter If You Weld The Inside, Its Fine...
Old Dec 16, 2005 | 09:43 AM
AMSTuning.com's Avatar
We've done numerous DC manifolds, all of which looked similar, and there has not been a single issue with one.
You're good to go.
Old Dec 16, 2005 | 12:55 PM
S-1's Avatar
S-1
great to know!
i'm gonna send it out to get coated and install after i put my car on the dyno for some base numbers.
it should fit the IX fine, but can somebody verify?
Thanks
