my stiffy whines?
Old Jan 17, 2006 | 11:40 PM
mitsuorder's Avatar
replace the supplied rubber o-rings with some poly or teflon washers. can be found at the local lowe's, builder's square, home depot.
Old Jan 17, 2006 | 11:47 PM
Missred's Avatar
mine whines also, At first i thought it was TC
Old Jan 19, 2006 | 10:27 AM
robstamina's Avatar
EVERYONE THAT HAS THE WHINE NEEDS TO DO THIS!!!!! What happens is that soft rubber o ring gets over torqued during installation and deforms causing the "whine". Replace it with a harder polyurethane plumbing o ring you can get at home depots plumbing dept. and the whine is gone! Take the supplied oring from the kit so you get an idea on the o rings diameter. I did this and it was gone...
Old Jan 19, 2006 | 11:08 AM
Jeff_Jeske's Avatar
I like the whine......
Old Jan 19, 2006 | 02:40 PM
robstamina's Avatar
Originally Posted by onesicklambo
Hey well just installed my "stiffy" and man, its awesome. I adjusted it right to the hardest setting, havent tried soft or med yet. Theres a noticeable difference in the shifting and when letting off the gas(doesnt jerk as much) only concern is im hearing alot of "whinning" coming through form the engine bay now. Maybe its road noise? It starrts when im in a low gear(1st, 2nd) and let off..coasting. Has this happened to anyone else? Thanks, stew
How many miles on your car cause the soft o.e. motor mounts might be worn to the point that it is tranfering the vibration/noise..Order some mounts from Hendersonperformance.com and in conjunction with the stiffy you will be VERY happy with the results.... Did you dynamat too? THAT LAMBO IS SICK!!!post up some pics of it or send a link....check the Ingalls stiffy reveiw for other ?'s and installation pics etc. It's on the home page on evom on the left..
Old Feb 10, 2006 | 05:35 PM
tjpdigital's Avatar
I just installed the Stiffy. I have the whine as well. I'll be sure to try out some poly orings.
mitsuorder and robstamina does this COMPLETELY eliminate the whine? Or just lessen it?
I don't *really mind it but I think it will get annoying over time.
kpt6
13
Aug 21, 2017 01:25 PM
hutch959
Oct 19, 2015 05:11 AM
Dropspeed
Midwest Region
Jul 10, 2007 07:49 AM
TTP Engineering
150
Oct 3, 2006 09:30 AM
MDoe8
Jun 30, 2006 08:44 AM
