Boost gauge!
Old Dec 28, 2005 | 01:01 PM
M3ss's Avatar
It's hard to say. If your Defi is showing 23psi and you don't even have a boost controller, then it sounds like it's way off. If the Autometer only shows right at 20psi at peak boost, then it sounds more accurate.
I don't know either ! They both read the same vacuum ! Ima hook up the autometer again and see if it'll pass that 20 mark ! Stay tune.....
Old Dec 28, 2005 | 01:30 PM
fromWRXtoEVO's Avatar
I use to have an utometer gauge on my WRX, I was putting 20PSI on a FP18G turbo, I took my car to www.dyno-comp.com for a tunning and when they connected the lines to the Dyno-Dynamic Dyno computer I was at 18PSI, that means that my autometer was reading 2 psi more which sounds consistent with what I heard from other people.
Old Dec 28, 2005 | 04:10 PM
M3ss's Avatar
thanks fellas im stickn with the defi
Old Dec 28, 2005 | 04:15 PM
Matz's Avatar
How did you determine the difference? Did you put in a T fitting and look at both boost gauges at the same time? I would be surprised at such a huge pressure differential. I would think that all boost gauge manufacturers calibrate their pressure sensors. But if you ran both next to each other from the same (T'd) boost line, then clearly I'm wrong.
Old Dec 28, 2005 | 04:17 PM
VRSF Tiago's Avatar
Looks like the second autometer has the car idling and the first one the car looks turned off.
Old Dec 28, 2005 | 06:40 PM
walkedu's Avatar
Thank you. Now i can sleep better.
Old Dec 28, 2005 | 08:30 PM
M3ss's Avatar
I didn't have them hooked up at the same time !
Old Dec 28, 2005 | 08:32 PM
M3ss's Avatar
U think!
Old Dec 28, 2005 | 08:34 PM
M3ss's Avatar
Ur welcome !
Old Dec 29, 2005 | 02:35 AM
GDB's Avatar
GDB
You are sticking with DEFI???
From my experience (and that of friends) Defi gauges ALWAYS over-read. That is, it will display higher boost than 'actual'.
Now of course there are differing views what defines 'actual' boost. These are the sources from which I compare the boost reading (against Defi):
- onboard diagnostics
- mechanical boost gauges
- digital readout on electronic boost controller
Old Dec 29, 2005 | 02:39 AM
Jakeg97's Avatar
Originally Posted by M3ss
and from what i can see they have the same vacuum but boost don't pass 20 on the autometer !
sounds like the evo with the autometer, was a stock 03
