Clutch slipping??
Old Jan 6, 2006 | 05:47 PM
Ckjeepin's Avatar
Clutch slipping??
My car started doing this today i noticed it on the freeway.. If i punched it at around 3500 it would jump to 4k then take off. I got a small vid...
http://s11.yousendit.com/d.aspx?id=2...53RZQ2ISTUZLIM
edit: you think its the clutch or ????
Old Jan 6, 2006 | 05:49 PM
gsrmin's Avatar
i think it's slipping
Old Jan 6, 2006 | 05:51 PM
Ckjeepin's Avatar
Old Jan 6, 2006 | 06:01 PM
gsrmin's Avatar
i had my cluch replaced. about 3weeks ago.. and it started at 4000 rpm
when it jumps... does the car moves forward(increase in speed) or stays ??
Old Jan 6, 2006 | 06:06 PM
Ckjeepin's Avatar
It increases speed. Kinda feels like a powersurge.
Old Jan 6, 2006 | 06:09 PM
3vo2005's Avatar
When my clutch went out. I would change gears and the rpms would go up 1k-2k and than drop down to where they shoudl be. Does yours do that? I can't really tell form the video its kind of short.
Old Jan 6, 2006 | 06:12 PM
Ckjeepin's Avatar
No it doesnt do that.. I can only duplicate what happens at 3500 to 4krpms..
If i floor it at 3500 it will spool up full boost hit 4k jump to 4500 and go
Old Jan 6, 2006 | 06:19 PM
nikkadanny's Avatar
thats how mine was..but i got my clutch replaced..
Old Jan 6, 2006 | 06:27 PM
Ckjeepin's Avatar
how long did it last after that started happening?
Old Jan 6, 2006 | 06:36 PM
Evoryder's Avatar
your clutch is done...
those are common symptoms of a slipping clutch... i managed to baby my clutch for 1-2 months of 3k shifts and mainting speeds of under 3k rpm....towards the end i abused it...and it still had bite...never totally died on me... its weird how it happens too...you step on the gas ...it pauses....and the car lurches forward and picks up where it should have been.
You should stop testing your car out to see if there is something wrong with the engine...or a bolt on mod that could be causing it ....it's your clutch...baby it for as long as it takes you to get another "real clutch" in there....i opted for the exedy twin disc...clutch pedal feels like stock...grips like a lesbian with a *****....chatters a little ...nothing major
Old Jan 6, 2006 | 06:43 PM
Ckjeepin's Avatar
damn
Old Jan 6, 2006 | 06:47 PM
Evoryder's Avatar
thats what i said...when i found out....mine happened right after someone drove my car for 2 secs while i drove her evo(emergency situation) ...got back in my car and punched first.... hit like a wall.....then boom jumps 500rpm and lunges forward ...i'm like? what the f did she do to my car? we just went around the corner.... 2 days later of me trying to figure it out...i find out it's the clutch...
...don't act like it was never going to happen...i just hope you planned for it...
Old Jan 6, 2006 | 06:50 PM
s q a d's Avatar
and this is the truth
Old Jan 6, 2006 | 06:51 PM
SEVEN's Avatar
LOL, that was hillarious
Old Jan 6, 2006 | 06:54 PM
SEVEN's Avatar
I have kind off the same problem....but mine is that if i rev up to 3500+/- RPM's, the RPM's jumps till like 3700 or so.....it happends if i get on boost, so i am going to order an ACT stree kit with the Fidanza flywheel very soon
