Flash
Old Jan 11, 2006 | 06:15 PM
aberabee's Avatar
what is the real deal with MPG? and what the heck speed are you cruising at to get 26-28mpg? i have always wondered if it was better to drive 55 or 75...
Old Jan 11, 2006 | 06:22 PM
HiRevnVIII's Avatar
well, the more MPG, generally the better because you are saving money. right?
Actually, as far as what speed will get you the best MPG...every car is different. Sports cars with taller gears, ie corvette, viper, etc with a 6th gear close to .500, would get better mileage going faster, maybe around 75 because it would be closer to the "sweet spot". Our car, with a shorter 5th gear, probably better slower, also the higher rpm for our car, easier it is to get into boost, which = worse MPG. hope that helps.
Old Jan 11, 2006 | 06:35 PM
BURNALL_4's Avatar
Bechbum, you should mention that you drive really far each day on the highway at cruising speed. I don't want people thinking they could or should see MPG that high. The vast majority of us only see 19-21mpg. In fact, even with no boosting for a full tank of gas, I've never gotten anywhere near 26-27mpg, which would be 340-350 miles per tank (I get 220-250).
+1 on your mileage i thought i was doing something wrong but i get the same.
