How do you gap spark plug?
Old Jan 11, 2006 | 04:16 PM
DanJ's Avatar
Don't use those cheap ones that lancershop sells (looks like a coin). I've heard that when gapping the plugs the coin can scracth the tip and damage the spark plug.
Old Jan 11, 2006 | 07:17 PM
Evolved Monkey's Avatar
Why not just buy new ones? they're only about 4-5 dollars each
Old Jan 11, 2006 | 07:21 PM
evo8rcr's Avatar
that was my inital thought especially looking at this guys supposed car list
Originally Posted by bcmind
Drives: Still have:05 Cayenne Turbo, 04 SL600, 04 COOPER S, 03 EVO, 03 M3 SMG, 03 911 Turbo (Lease ended)
$20 for plugs instaed of regapping when you drive over $250,000 worth of cars seems pretty reasonable
Old Jan 11, 2006 | 07:56 PM
BURNALL_4's Avatar
GUYS, stop making fun of the kid, you all had to learn too. none of us were born w/ a spark plug in one hand and a gapper in the other.
Old Jan 11, 2006 | 08:03 PM
CoEvo05's Avatar
omg i can believe none has said anything......
1. if it came with a plastic cap over the end it doesnt need to be gapped and if u do it will hurt it more then help
2. if u bought iriduim/ platium plugs if you gap them then you will scratch the iridium/ Plat off the tip and eathier cause premature wear/ failer so my answer to you would be throw those away and go buy new ones and dont touch them! lol just put them in the car and walk away!
Old Jan 11, 2006 | 08:11 PM
dryad001's Avatar
Originally Posted by Aux.
No gapping skills... and you bought an EVO ? Uh-ohh sounds like a big learning curve ahead of you !
Theres an understatement. How are you going to get the plugs out of the engine?
Old Jan 12, 2006 | 12:52 AM
Jakeg97's Avatar
So actually the part that can be move is the outter metal tip?
I was trying to push the inner down... LOL
lol - not good
the outer metal L shape is the one 2 bend
Old Jan 12, 2006 | 12:57 AM
Jakeg97's Avatar
dont buy the lancershop one , cause you find the same gapper at your local auto parts store for like .50 cents
however it does work , you just have to be careful around the tip. using needle nose pliers to gap also works. but the cheap tool measures just fine
Old Jan 12, 2006 | 11:06 AM
purplegodzilla's Avatar
I just tap mine on a hard surface and recheck it afterwards..Usually takes about 2-3 taps.... Yes, I am ghetto but it works...
Old Jan 12, 2006 | 11:33 AM
Cajun Power's Avatar
Enough already...
Here:
The inner on a copper plug is a cylinder surrounded by ceramic with a bit of the copper cylinder showing. This is all molded in place and doesn't move at all. On a regular plug (not a split fire or Bosch+4 multi electrode style) there is an arm that reaches from the threaded outer part of the plug body up over the copper cylinder and looks like a rotated "L". this is the part that you adjust (bend).
Use a gap tool (on copper plugs any gap tool works). Check the gap. If too big tap on the L to shrink the gap. Tap on the floor, or use a wrench handle, or anything. Just tap not hit! remeasure until it is the right gap.
If too small use a pair of small needle nose to grab the L in the bend and rotate up/away from the cylinder. do this until right. try not to scratch or mess up the cylinder.
*****Iridium plug are done with ONLY a wire type feeler and try not to scrape the cylinder at all!!! Other feelers will bend the tip. You can tell an iridium plug buy the center cylinder. It looks like a mini Hershey's kiss not a cylinder. /\ vs. |-|. You will see what they look like when you remove one of the stock plugs. They are iridium. If you still have the stock plugs in.
Good luck. PM me if you ever need any other help. Glad to see you are willing to try to do something new and learn.
Old Jan 12, 2006 | 11:47 AM
Invoice EVO's Avatar
Veteran: Air Force
I don't like the metal token one.
This one from sears has a little tool to help adjust the gap and is way better than the token gapper
http://www.sears.com/sr/javasr/produ...id=00940801000
Old Jan 12, 2006 | 11:55 AM
justchil's Avatar
Ditto on that..
blade type = works great!
Old Jan 18, 2006 | 07:45 AM
housedj's Avatar
Thumbs up
just picked up a set of 1 step colder ngk iridiums & they are PREGAPPED to 27mils (or .027" for common folk). no need to gap those at all.
Old Jan 18, 2006 | 08:08 AM
bcmind's Avatar
Originally Posted by Cajun Power
Enough already...
Here:
Finally, the reply that I'm looking for.. Thank you very much!
Old Jan 26, 2006 | 09:14 AM
Derek888's Avatar
I made the inside black piece go down a bit...the thing under the L shape bend. Is my spark plug damaged?
