How do you gap spark plug?
Old Jan 11, 2006 | 02:05 PM
bcmind's Avatar
^^^^ what the title says...
I got the NGK and i want to gap it at .025.. but i'm kinda confuse on how to gap it...
Old Jan 11, 2006 | 02:07 PM
Kodiak's Avatar
http://www.lancershop.com/customer/p...9&cat=0&page=1
Old Jan 11, 2006 | 02:09 PM
bcmind's Avatar
I have the tool...i just don't know how to use it
bigjhoney's Avatar
Why are you gapping so small, your idle would appreciate being set to .028
Old Jan 11, 2006 | 02:11 PM
Aux.'s Avatar
No gapping skills... and you bought an EVO ? Uh-ohh sounds like a big learning curve ahead of you !
Old Jan 11, 2006 | 02:13 PM
bigjhoney's Avatar
Stick the piece of metal of the gap size you want in between the tip and metal. When your gap size fits in there snug, its gapped. If you got the right ngk's for the evo they are usually always set to .028 out the box, i personally would leave it there, but I would check to be sure. You sure you know how to change the plugs right besides gap?
Old Jan 11, 2006 | 02:26 PM
bcmind's Avatar
your reply is worthless
Mookie's Avatar
Just cause you have never physically gapped a spark plug doesn't mean you don't know anything about cars or are not mechanically inclined. Just saying....
Old Jan 11, 2006 | 02:28 PM
Aux.'s Avatar
Read what is said not how its said. Still doesn't change the fact that your asking how to gap a plug. I'm sure if you search it would tell ya. Good luck out there.
bcmind's Avatar
yes i know how to change it but i just don't know how to gap it...
So i just "push" the inner part of the plug down?
Old Jan 11, 2006 | 02:29 PM
nutrulz's Avatar
Get a pair of pliers and eyeball it.
Old Jan 11, 2006 | 03:06 PM
bigjhoney's Avatar
nooo dont do that. If it way to small open it up more with pliers or something, if is close just wedge the gapper in until it fits good. But if the gap is to big knock the plugs metal rod over the tip on the ground or something lightly until its that gap. Never push on the tip.
Old Jan 11, 2006 | 03:15 PM
bcmind's Avatar
So actually the part that can be move is the outter metal tip?
I was trying to push the inner down... LOL
Old Jan 11, 2006 | 03:24 PM
housedj's Avatar
if they are the iridium plugs you have to gently pull up on the metal with the gapper tool. the electrodes break real easy so be careful. they should be pregapped to around .026-.028 tho
Old Jan 11, 2006 | 03:25 PM
evo8rcr's Avatar
holy $hit please put all the tools down and back away from the vehicle I don't want you to hurt yourself!!! also next time you are driving on the freeway and need a bump in speed slam the peddle in the middle the rectangle one and you'll jump like 5 car lengths
