As requested, here's a vid of my 2-step Dynoflash launch control
Yes, for those who have the switch (05/06), it must remain connected in order to work. The flipside to this is that we can deactivate it whenever we want if we have trouble with the limiter...
and some kind of switch needs to stay connected
Originally Posted by vwjeff
What switch are talken about? What exacly is needed to make the 2 step work. So far I got a flash
thats the speedfactor exhaust
www.thespeedfactor.com
there is the clutch switch which is triggered when the clutch is pressed in to start the car. on the 05 and 06s they had an added feature "launch control." when the clutch was pressed in and you matted the gas (from a standstill) the engine would cut off at 5k.
with a flash from al, the rev limiter on launch control is raised to whatever rpm you want and also, for some reason ( i don't know ) there is an anti-lag effect where you build boost
That is what I wanted to know I believe that switch has been disabled in my car for the alarm to act as turbo timer and remote start. I will have to ask the tech that installed it.
Thanks for the info.
if you had a remote start installed by a professional, he shouldn't have disconnected the clutch start switch. by doing so, this allows the car to start even while its in gear. i would expect a company that does remote starts professionaly would keep the switch on for liability purposes.
remember there are 2 different switches. the rev limiter switch and the clutch-in start switch
Hmm, yeah, it was posted up by someone else, and now it's down. Someone else had it on their HD and posted it in the Drag forum, so I'll go try to find it.
I use Youtube all the time for my vids, but this vid was taken by someone else who uploaded it to Streetfire, and the link no longer works. I don't have a copy of the original file unfortunately, and I can't find the other copy that was posted by someone else at a later date.
All I have is an in-car vid from a 12.30 run:
http://www.bagelbitez.com/dcevoclub/Warrtalon/12.30.mpg
