My Turbotrix tuned evo ix
I've been waiting for some dynotune # at TT with the IX. The EVO 9 is making some good numbers. My 03 tuned by Mark makes the same HP but with the addition of Cams and header. Also my car have been running fawlessly in the last two and a half years with close to 500 runs in autox and 8 trackdays. The car performed well that I never have to worry about any mechanical or tuning failure, took year end Champion in SCCA Solo2 in NY region (SM), North NJ region (SM), NASA NE region (A class), BMWCCA NY chapter (F class) in year of 2005.
I'm in the process of returning my 03 to stock and will trade it in for the IX at the end of this month to run in BSP next season or SM if I go with cams. I'm shooting for around 350hp with pump and around 360hp with 100oct with basic bolt ons. It should be benifitial with the way how the power deliver with the mivic and with the ACD to put them on the ground.
Kevin
Kevin
Originally Posted by brandon
http://digitaldetroitradio.libsyn.co...s/mmmullet.jpg
I know i wouldnt buy parts from this guy. Everything i have seen from buschur has been garbage. I have seen there parts there motors and have seen how they have treated customers and the local shops and can honestly say that buschur= cheap halfed *** ****.
Great #'s after the tune TT !
Originally Posted by AzBlackEvo8
you're loosing some power with that turbo XS boost controller. I know cause I switch it to forge MBC and it was a night and day difference. Not saying that they're bad mbc, for honda cars that only boost up to 7psi, it's good but our cars boosting at 21psi, the boost doesn't hold well with the Turbo XS MBC. Nice numbers tho!
The bleed hole in the TX is too large and it creates a significant boost leak - it seems to be less of a factor with the IX than with the Evo 8 due to the larger turbo
i like the hallman, Forge, and Buschur MBC's - they are all super on evos
Btw - the new Blitz color display EBC is a really nifty unit, I played with one of them this weekend - it is interesting
I agree with the TurboXs boost controller being a poorly designed MBC. I had problems with mine, Mark swapped it out with a Halman and the boost holds very nicely now.
Edit: Plus I must have lost about 3 hex wrenches trying to adjust the thing.
Thanks for the baseline. None of our stock IXs dyno'd higher than 254whp/255wtq at our Dyno Day on Sunday (dynojet), so that helps with the comparison, although yours may just be faster, because your trap speed matches those readings...
hova,
Thanks for the compliments on our service and the exhaust. The systems fit great and are a breeze to install, as you saw.
Again, nice power numbers.
David Buschur
www.buschurracing.com
David Buschur
