Used EVO or STi for rally/snow/DD?
Originally Posted by DaWorstPlaya
If its off-road and you are choosing between the 03/04 EVOs and the 04 STi. The STi is the better choice for rallying out of the box because:
1. Front LSD (suretrac)
2. More compliant suspension with longer travel (more ground clearance)
3. DCCD (active center diff) is better suited for loose surface with low traction
4. ABS because the 04 EVO RS model has the front LSD but no ABS
Now if you are going to mod with suspension components, eg: coilovers and front LSD installed on the EVO, the EVO is the better choice. If you decide to throw the 05 EVOs in as an option then the EVO wins hands down. The O5 EVOs come with the ACD (active center diff) and front LSD.
The only thing I would do is take the camber out of the back, I would run -.75 in the front and -.5 in the rear with a little toe-in in the rear and a little toe-out in the front. The stock suspension works great in the snow and I have had no bottoming issues even at high speeds on frozen fields (check out the pics in my gallery
) and remember WS-50s only (and keep them fresh, try not to EVER corner hard on dry or even wet pavement)!
chronohunter, how would you compare the 03/04 (without the front LSD/ACD) to the LSD/ACD equipped cars on a tight track vs. a higher speed track. Sorry for asking such a broad question.
Thanks.
Thanks.
Owning an 04' STI before I would have to say if you plan on not doing many mods, go with the STI. That extra torque is nice to have down low. The rumble along with power it'll make with a couple of simple mods is addictive. Some like the STI interior better, personally after a month or so, you realize it's all cheap but the EVO seats are hands down......much better to say the least. To me, the STI seats are "faux" racing seats. Let us know what your decision is.....
Aashenfox
Nov 29, 2014 10:34 AM
PSUfan1
Sep 22, 2013 07:25 AM
radiantm3
25
Apr 5, 2013 11:27 PM
FERNO
40
Feb 24, 2011 09:34 AM
