Strange Driving Characteristic on EVO9: Is that LSD? ACD?
Old Jan 21, 2006 | 03:12 PM
shiftdsm E's Avatar
Makes sense to me, im not saying im right, i just put together the info i saw/read/heard before. cheers to figuring it out
but bottom line, you gotta drive another 06 and recreate the situation thats the only way that you can kno if there is something wrong w/ yours
Originally Posted by ShiftySVT
I edited out the my statement about torque distribution. Strictly speaking, I think it DOES control torque distribution.
Imagine that the front tires are on a theoretical surface with a coefficient of friction of zero (no traction at all) and the rears are in sand. If the differential is completely open, it must send equal torque to the front and rear. If we ignore the effects of the moment of inertia of the wheels, there will be no torque transferred to the front wheels (refer to Newton's 3rd law - you can't push on something if there is nothing to push back). Consequently the rear tires will receive no torque, so you're stuck.
Now consider that the ACD locks up the center diff. Now the front and rear tires must spin at the same speed, which forces the rears to receive ALL of the torque.
I'm not saying this is exactly how the ACD works, but it shows that strictly speaking, the process of locking and unlocking the center diff does change the way torque is distributed.
Old Jan 21, 2006 | 03:17 PM
shiftdsm E's Avatar
Originally Posted by zstryder
All the ACD does is control the speed at which the center diff locks/open depending on a variety of inputs. It does NOT work like Subaru's DCCD system, which, IIRC, actually does control torque distribution from front to rear. The torque distribution in an Evo is always 50/50.
Right!!! but what is the result of the differential locking???
Old Jan 21, 2006 | 03:18 PM
RobDogg's Avatar
I think I've noticed the same thing, So i've been adjusting my steering wheel height every frigging day
Old Jan 21, 2006 | 03:23 PM
zstryder's Avatar
You could say that it controls torque distribution in a certain way, which it is, but what it is NOT doing is transferring unused torque from the front to the rear, and vice versa. The amount of torque generated is always split 50/50, how much of that 50% is actually used up by a particular axle is dependent on the conditions of the road, driver input, and the differentials.
Old Jan 21, 2006 | 03:26 PM
Maron's Avatar
Originally Posted by xtnct
I just switched from EVO 8 to EVO 9. 9 has the LSD & ACD. I noticed a strange driving characteristic or behaviour with the new car that was not there on the EVO 8.
Assume you are crusing on a straight road. Ahead is a long constant radious bend in the road. Once you turn the steering wheel, holding it in the same position would take you around the bend. However, on the EVO 9, once I had my steering angle for the entire curve I have to readjust it if I either apply more throttle or get off the throttle. If I apply throttle, the car ends up wanting to go straight, so I need to compensate with the steering wheel (just a tiny bit). If I let off the throttle, the car wants to turn into the turn and I have to compensate again with the steering. This is a very weary subtle feeling that I would not want to experience at higher speed (kind of like a twich). Could this be the ACD or LSD in action even when miles away from the car's actual limits?
I had a FWD car with LSD and it did not have that behaviour. I can tell you definitely what it is NOT:
- not oversteer or understeer,
- does not feel like an alignment issue
- it is not a weight trasfer characteristic
- it is not new tire break in as they are the ones I trasfered from my 8.
Changing ACD setting makes no difference. It feels more like something mechanical is happening, like something is steering the rear wheels for me...
Note that I did not WOT it around the bend. This was just cruising @ 50mph around 3K rpm and just applying moderate throttle in 5th and then easing off before full boost kicks in. I have 40 miles on the odomoter so I have not experimented with what happens at WOT and full boost.
So, would this be ACD and or LSD behavior or should I get my new car checked out?
It is the more instantaneous throttle response of the IX. I wouldn't categorize it as been twitchy. The almost instant power got the front diff to start working and putting the power down sooner. I noticed the same thing when I autocross jumping from my VIII MR to my IX MR and I loved it. It behaves almost the same way as my old 04 STI where I felt the front end grabbing a lot sooner. With the VIII MR, I used to get on the gas or try to modulate the throttle but there was always a small gap as to when the power actually made it to the front diff. It would come on only when I start to straighten out the front wheel. The IX just bites harder. Don't see it as a downside. Once you're used to it, you'll appreciate the benefits.
Old Jan 21, 2006 | 03:33 PM
Maron's Avatar
so then, what would be the function of the ACD? if not to adjust torque split front/rear it certainly cant do side to side
errr your LSD's front and back takes care of that part. The LSDs will tansfer power to the wheels that has the most grip or contact with the road.
Old Jan 21, 2006 | 04:12 PM
an0ther's Avatar
The ACD springs into action, distributing all of the 4G63 engine's raw power through a hydraulic multi-plate clutch. It adjusts front and rear torque output for maximum traction based on numerous inputs like steering angle, throttle input, wheel speed and slip angle.
This is from the US evoIX brochure that I picked up when getting my oil changed the other day.
Old Jan 21, 2006 | 06:43 PM
i11matticc's Avatar
ive heard so many different renditions of how the awd system of the evo works, i confused myself and dont even know anymore...all i know is that its bada$$...
but whenever i get confused i go to the website and find the official explanations for it from mitsu themselves, if im still confused, i search here and look for credible answers
Old Jan 21, 2006 | 08:06 PM
501's Avatar
501
in long sweeper corners i have experienced the same twitchy type of feel in my IX and i am also coming from a fwd lsd car. maybe the car will feel more balanced after the ride hieght comes down some. has alot of body roll in long turns maybe the valving on the shocks could have something to do with it. just a thought, because the car feels tighter around a quick radius.
Old Jan 21, 2006 | 09:28 PM
Maron's Avatar
That is a first, a stock evo that feels twitchy?
I'm not going to promote trying to test your car on public roads but I can assure you that the evo IX is anything but twitchy. In the long sweepers is when its at its best. Try looking deeper into the turns instead of directly infront of you. I honestly don't think that you have any idea of how much grip and the amount of cornering speed you can carry around the wider sweepers.
Again, please do be careful out there.
Old Jan 21, 2006 | 10:11 PM
501's Avatar
501
yea it could be just getting used to the steering as it is sensitive. havent had the oppurtunity to really get a chance to drive aggressivly in corners autox season hasnt started and the weather is wet around here. but it has been slightly wierd that the car would feel unbalanced in the corners, compared to my last one which had suspension mods done to it.
Old Jan 21, 2006 | 10:59 PM
sponge bob's Avatar
[QUOTE=xtnct]If I apply throttle, the car ends up wanting to go straight, so I need to compensate with the steering wheel (just a tiny bit). If I let off the throttle, the car wants to turn into the turn and I have to compensate again with the steering.QUOTE]
What you just described is completely normal behavior for any car.
Old Jan 21, 2006 | 11:16 PM
dacrazydude's Avatar
yeah, I agree with sponge bob, I'm not quite getting what you meant
When you step on the gas, a car will take a wider turn...so....eh?
Old Jan 22, 2006 | 01:01 AM
SoEvoL's Avatar
well this seems intresting, im going to try it in my integra and evo and see how it feels on and off throttle
long sweeper @ 50mph
Old Jan 22, 2006 | 02:18 PM
xtnct's Avatar
I said like a twichy feeling due to the lack of a better term. It is not really a twich as it was a result from applying or getting off throttle and the speed was way too slow to get the car twichy in its real definition. A better way to describe is to assume the car has 4wheel steering and someone else is steering the rear wheels for you by a small margin when applying getting off throttle.
Thanks, but this is not about driving lessons. It has nothing to do about looking ahead in turns. If you recall my orginal post, this is experienced putting around, not anywehere close to what the EVO limits are. This is not doing WOT or even hitting full boost.
Then why was this not apparent in my EVO 8 that I had for the past 3 years or my FWD car with LSD or our Audi a4 Q?
I don't think that is it either. The steering sensitivity is the same as my 8 was.
Maybe I'll get a passenger and try to make a short vid of the behavoiur...then I will not have to describe it and you can all see.... I'll attempt that this week...
