boost leak.
Old Jan 22, 2006 | 04:19 PM
bigtymer's Avatar
boost leak.
hey, i have a really bad boost leak its not the bov b/c i keep changing it... when i boost to about 20 psi the boost goes way down and the rpm's go up.. whats going on here?
Old Jan 22, 2006 | 04:36 PM
Z-Ball's Avatar
what happens after the rpms go up?
Old Jan 22, 2006 | 04:41 PM
Warrtalon's Avatar
Heh, you just assume that's a boost leak? It sounds more like your clutch is slipping. A boost leak would not make your rpms go up.
If in higher gears, when you go WOT from low rpm, and the RPMs shoot up when you hit full boost, then your clutch is slipping.
Old Jan 22, 2006 | 04:45 PM
Z-Ball's Avatar
ya my clutch started slippin last week, the way u make it sound dont sound like boost leak
Old Jan 22, 2006 | 04:56 PM
vboy425's Avatar
here is a test to see if your clutch is ***. get on the freeway put in 5th gear at about 50-55mph and floor it, if your RPM go up and you're not picking speed. your clutch is slipping. i did this test on my car.
Old Jan 22, 2006 | 04:57 PM
Warrtalon's Avatar
Vboy, I already said that...
Old Jan 22, 2006 | 05:06 PM
vboy425's Avatar
my bad Warrtalon, i didn't se your post, anyway just makemy repost of what you said as a breakdown how to Barney style. :-)
Old Jan 22, 2006 | 05:09 PM
bigfishs's Avatar
If you are stock, then the boost will go down as the RPM go up. 21 to 17 pis is close to norm over our power range
Old Jan 22, 2006 | 05:50 PM
bigtymer's Avatar
id like to think its not the clutch.. its a brand new evo 9MR.. and it does it in every gear.
Old Jan 22, 2006 | 05:58 PM
RTS EVO VIII's Avatar
that's completely normal. peak boost for evo 9 is around 21 psi and it tapers down to approximately 16psi when it hits redline. if there's a boost leak i don't think you can even hit 20psi.
scott yo's Avatar
did you mess with the stock intercooler pipes tighten them and see if that helps
Old Jan 22, 2006 | 06:02 PM
bigtymer's Avatar
i was thinking thats what it might be.. im going to go try that.. thanks everyone.
Old Jan 22, 2006 | 06:37 PM
Warrtalon's Avatar
I am quoting this again, because it is being ignored. Obviously, the boost tapers down as your RPMs increase, but I'm sure that's not what you're talking about, right? I mean, you didn't think the boost stayed right at the same level from 3500-7000rpm. In 3rd and 4th gear that takes quite a while and the boost doesn't drop right away. When you said "and the rpm's go up," were you just referring to the standard increase of RPM while accelerating? If so, then why mention it? I figured you said it, because the RPMs shoot up right away unnaturally...no?
Old Jan 22, 2006 | 06:47 PM
bigtymer's Avatar
thanks scott yo.. and everyones insites..i found the problume.. the intercooler pipes were a little loose now i have full boost. By the way car isnt stock.... ecutek reflash tuned by sean ivey..... turbo xs turboback exhaust ....walbro fuel pump.... forge bov. -thanks-
