Proper way to launch the Evo?
Old Jan 23, 2006 | 06:12 PM
Fusion7's Avatar
Please explain..
Old Jan 23, 2006 | 06:21 PM
Warrtalon's Avatar
Here's one way. What I do is get my revs up to 5500-6000rpm while stationary, then ever-so-lightly start to let out the clutch. As the clutch barely starts to grab, it will remove the drivetrain slack. After it has done that, it will slowly start to roll the wheels. Just as this happens, I hammer the gas and release the clutch quickly. Here it is in action:
Warrtalon's 12.000
Old Jan 23, 2006 | 06:23 PM
Fusion7's Avatar
Nice run.
Old Jan 23, 2006 | 06:28 PM
evo8rcr's Avatar
I can't see the video
Old Jan 23, 2006 | 06:31 PM
dsmfan95's Avatar
I use the stock launch control right now. I've gotten a few better 60's w/o it, but I'm much more consistent with it.
Old Jan 23, 2006 | 06:32 PM
akEvo's Avatar
http://www.streetracing-syndicate.co...nchControl.WMV
Old Jan 23, 2006 | 06:37 PM
Warrtalon's Avatar
Haha, well that's me, too, but with the new 6k launch control on my Dynoflash. I haven't had a chance to test it at the track yet to confirm that I can get great 60's. I still use the same method as above except that my foot stays planted on the accelerator instead of having to try and modulate the revs.
Old Jan 23, 2006 | 06:40 PM
dsmfan95's Avatar
I'm waiting on those results so I can see if that's the route I want to go.
Old Jan 23, 2006 | 06:41 PM
SwabeLife's Avatar
I need to practice that launch.
Old Jan 23, 2006 | 06:46 PM
Warrtalon's Avatar
Well, here's the thing. Since you have an 05, you can get the Dynoflash and choose the launch control rpm (5500, 5750, 6000, whatever), and if it doesn't work, you can still disconnect the 5k limiter switch (works the same after the Dynoflash), and then you can launch at whatever rpm you want. Also, if your first rpm level doesn't work, then you can have Al change it to another one.
Old Jan 23, 2006 | 08:20 PM
fellowx's Avatar
DAYEM!!! that is one nice (__!__) launch..
Old Jan 23, 2006 | 08:31 PM
Hunt27162's Avatar
Wartalon, What was your 60' on the 12.00 run?( nevermind clicked on the link in your sig)
Old Jan 23, 2006 | 08:32 PM
funnyclub's Avatar
Nice run Warr.
Old Jan 24, 2006 | 01:21 AM
Jakeg97's Avatar
nice ^^
Old Jan 24, 2006 | 05:21 AM
Boltz.'s Avatar
FCOTM Winner
^says 1.666 in his sig....
