Aftermarket HID problem...NEED HELP!!!
Old Jan 28, 2006 | 03:59 PM
Blue Evo 8's Avatar
I've had aftermarket HID's on my non-ssl EVO for about 6 months now. Now one of the bulbs is not lighting up although I can hear the ballast buzzing though as if it wants to light up....
what could be wrong? Do I have a fried bulb? a bad ballast?
Old Jan 28, 2006 | 04:12 PM
Ultimate CC's Avatar
I would guess the bulb, switch bulbs from one side to the other and see if thats your problem
Old Jan 28, 2006 | 05:00 PM
burgers22's Avatar
Hi
I had a similar problem with my JDM Evo 7. Thurnd out to be one of the connectors to the box not making properly. It is well worth cleanig up all the conectors & then putting a very slit twist in them so they make a bit better. Be careful not to over do it as you may damage the conectors doing it or trying to get the conectors together.
To get the headlamps out you need to remove the splitter, not to had but you have to get all the plastic snap conectors off the front of the splitter & some from in the wheel arches. ther are 2 bolts on the top 1 one each wing & 2 on the intercooler mesh. You'll need to do all this to get the bulbs out anyway.
MB
Old Jan 28, 2006 | 05:08 PM
Blue Evo 8's Avatar
Originally Posted by burgers22
Hi
MB
thanks for the input. My brother also suggested I use diaelectic grease on the terminals to prevent the terminals from corroding, and also to aid in the electric currents flow...
what do you guys think?
evo89_
Nov 1, 2013 07:36 AM
robyn402
Oct 18, 2010 08:18 PM
StevenStarke
14
Jan 19, 2009 09:35 PM
randomevo
Jul 21, 2008 08:16 PM
w8lifter21
Feb 11, 2008 08:53 AM
