power
Old Feb 1, 2006 | 09:13 AM
J!n K@z@mA's Avatar
power
i have almost all the parts but i havent installed them yet. i'm just askin about a rough estimate how much WHP/HP will i get from these parts
HKS intake
HKS ti xhaust
hks downpipe
JIC xhaust Man.
helix High flow cat
HKS 262/272 cams
greddy EBC
Jestr ECU 2nd stage flash
i don't get accurate answers from my seach and to other pple, so i'm asking you guys about your knowledge
Old Feb 1, 2006 | 09:15 AM
WrX Kila's Avatar
330whp maybe.
Old Feb 1, 2006 | 09:43 AM
nbpal4000's Avatar
somewhere around 310-315whp on dynojet and if you go catless, probably 330whp range on dyno jet
Old Feb 1, 2006 | 09:46 AM
J!n K@z@mA's Avatar
how about from crank
Old Feb 1, 2006 | 09:48 AM
4TUN8's Avatar
No way for anyone to know at the crank sir, and having what numbers you have at the wheels is far better IMO.
Old Feb 1, 2006 | 09:49 AM
AndyBandy's Avatar
probably 310whp on dynojet
Old Feb 1, 2006 | 09:53 AM
nbpal4000's Avatar
crank calculating 20% drivetrain loss from 310 and 330 would about
360-390 CRANK
Old Feb 1, 2006 | 09:54 AM
dubbleugly01's Avatar
no dp? Do you have the 10.5 hotside? If "no" to both, numbers quoted above may be a bit high.
Old Feb 1, 2006 | 09:55 AM
hondafan's Avatar
do you have an 03-04 or an 05, probrably makes a slight difference.
Old Feb 1, 2006 | 09:56 AM
AtO-MiX's Avatar
ur not going to get accurate answers this way either....thats why its called guessing.
nbpal4000's Avatar
oops no dp? then yeah it is too high
but 03 evos without 10.5 do make 310-330whp with cams
Old Feb 1, 2006 | 09:57 AM
silverEVO8's Avatar
I'd say 50~70 whp more than stock..... It could be as most ppl say. My car with only XEDE (nothing else, nada, zip) makes 249.3 whp od DD dyno = 280~290 whp on Dynojet. The cams should be good for 30 whp (maybe I'm wrong here, seems I remember those numbers from some article..), the intake and exhaust prolly gain another 20~25 whp. You do the math.
Correction, my car is an '05 MR. The '03 EVOs tend to put down considerably less power for some reason....
Old Feb 1, 2006 | 09:59 AM
nbpal4000's Avatar
depends on cams.. 264/264 setup is about 15whp according to David Buschur. But I dont know how much 264/272 set up will give.. some say not much..
oh yeah 05 makes more power. i think 10.5 helps
Old Feb 1, 2006 | 11:39 AM
Nood1es's Avatar
+23412341234
Old Feb 1, 2006 | 12:57 PM
J!n K@z@mA's Avatar
sorry i also have hks downpipe, 03 evo by the way
LancerShop.com
Oct 6, 2016 06:12 PM
LancerShop.com
Sep 22, 2016 06:05 PM
jamdread
22
Oct 16, 2009 11:50 AM
Nasty Evolution
Jun 22, 2009 01:50 PM
