Random Cyl. Misfire?
Old Feb 15, 2006 | 10:11 AM
Big Shooter's Avatar
so i changed my oil a couple weeks ago. i put in 5 quarts. noticed it was over the line. looked around on here and saw that the evo only takes 4.6 or something. but i figured since the car burns a bit of oil anyways ill just take it easy on it until it burns off the extra. well i didnt really take it easy, it went two weeks just fine but yeasterday i got on the freeway and as soon as i hit 80ish my check engine light came on. i took it to autozone today and it read P0300 random Cyl. misfire. he cleared the code and it didnt come back during the ride home. ill drain the extra off tomorrow. im just wondering if i could have actually damaged my motor?.
Old Feb 15, 2006 | 10:13 AM
hotrod2448's Avatar
I don't think your oil level has anything to do with the p0300. Alot of 03's had this issue.
Old Feb 15, 2006 | 10:19 AM
well i was kinda wondering if it did or not, but i thought that was with a rough idle or something
Old Feb 15, 2006 | 10:21 AM
gb_junkie's Avatar
get used to it buddy, that p0300 is going to be with you for a very long time (maybe even the life of your car). as long as it's just teh ember light and semi rough idle...drivability issues should be nill. but there are some ppl that get the crazy 3500rpm 300 code that causes the car to stutter.
you might want to try getting a dynoflash from Al...it may be able to fix this.
Old Feb 15, 2006 | 10:25 AM
my idle is steady. so i can still beat my car like a readheaded stepchild right? should i even bother draining the extra 1/2 quart?
Old Feb 15, 2006 | 10:29 AM
hotrod2448's Avatar
Mitsu bought back my first Evo because the P0300. It had a miss that would just about put you through the windshield though.
Mitsu has a reflash that is supposed to take care of it but, I don't know if it actually works or not.
Old Feb 15, 2006 | 10:30 AM
bigfishs's Avatar
Drain it to the correct level and keep an eye on it (every other gas fill)
Old Feb 15, 2006 | 10:31 AM
so im guessing ill be able to tell if the car is actually misfiring. or could it sound fine and still be mildly fu@ked up?
Old Feb 15, 2006 | 10:36 AM
Ekasey's Avatar
probably just a fluke
Old Feb 15, 2006 | 11:05 AM
alright ill drain the extra, say a little prayer, and continue to thrash it
Old Feb 15, 2006 | 03:50 PM
zmeli's Avatar
I hope your car is stock and still under factory Warrenty. P0300 is not good. I had my 04 Lemon Lawed because of it. If you are not under Warrenty just clear it and go. In Ca the car will have trouble passing Smog with P0300 in the PCM Memory. This will be a issue if you sell the car over here, the seller is required to provide the Smog Cert.
