Anybody try the greddy informeter?
Old Feb 21, 2006 | 09:05 AM
rcheung's Avatar
http://www.lancershop.com/customer/p...0&cat=0&page=1
I was thinking of getting one of these instead of the three gauge pillar pod I used to have because it was stolen once and I dont want it to happen again. Does anyone know which parameters this unit will show for the evo?
Old Feb 21, 2006 | 06:06 PM
rocket900rr's Avatar
Its a cool little unit. In my Evo it reads: speed(mph), tach(rpm), water temp(f), ignition(degrees), intake temp(f), A/F-C(%), injector(%), ARFL(%), O-2 sensor(volts), throttle(%), battery(volts). It has yellow & red warning limits that you can set for: speed, tach, water temp, battery, & injector. For instance my tach warning limit is set at 6500 rpm for yellow & 7000 rpm for red. When you hit 6500 the Greddy unit highlites the tach in flashing yellow & sounds a mild tone, at 7000 it flashes in red & has a more serious tone. It also reads SES light codes & can reset codes. It comes with about 8 different colored face plates. All in all I like it. I got mine for $275.00 shipped from intensepower.com
Old Feb 21, 2006 | 06:09 PM
hondafan's Avatar
you should go with the guages, the greddy unit just shows what apocketlogger will show and datalog for half the price. your boost won't show in psi, it will tell you your MAF reading, no oil pressure. it does show timing, rpm, narrowband 02, and coolant temp, but really what good are they without datalogging capabilities?
Old Apr 7, 2006 | 12:17 PM
TURBODAWG's Avatar
Does the injector % show up for the Evo? Does it read injectory duty cylcle % or in (ms) milliseconds? What are the units for MAF flow?
Do you have any pictures of it mounted in your car?
Thanks
Brian
Old May 2, 2006 | 07:33 AM
outsider's Avatar
So it does read SES codes huh? Interesting...
Where'd you mount it?
Old May 2, 2006 | 07:43 AM
TURBODAWG's Avatar
It does read SES lights, well it says it does. It has a setting for it. I didnt have any codes for it to read, when I tried mine. I have a used one for sale, if anyone wants one. Here is the thread: https://www.evolutionm.net/forums/sh...ght=informeter It worked great, used it to check duty cycle on the fuel injectors. I already have a pocketlogger, so I decided to the informeter it, because I need some cash now. It worked very well on my car though.
Brian
EvolvedAK
Aug 8, 2013 06:50 AM
NYR Solo
Northeast Region
Nov 17, 2012 12:10 PM
Crzylizard
Apr 21, 2003 02:12 PM
