View Poll Results: vote for one
Ralliart
50.00%
Powerflex
50.00%
other
0%
Voters: 8. You may not vote on this poll
Whats the difference between Ralliart motor and tranny mounts vs Powerflex the set
Old Feb 21, 2006 | 09:11 PM
evo8silver's Avatar
Whats the difference between the mounts of ralliart vs powerflex? please post facts no bias (as much as possible) Also post why one is better.
Old Feb 22, 2006 | 04:43 AM
Jakeg97's Avatar
my vote is for powerflex, cause its gotta be cheaper than ralliart
plus the guys at forge are cool
https://www.evolutionm.net/forums/sh...d.php?t=170862
Old Feb 22, 2006 | 05:08 AM
justchil's Avatar
Not much to compare other than the durometer (whatever it's called) and the price.
Old Feb 22, 2006 | 05:10 AM
kmcconn9's Avatar
The ralliart mounts are full replacement set for all of your mounts. The Powerflex bushings are replacement bushings that take place of your old bushings in your existing mounts...
Old Feb 22, 2006 | 06:35 AM
kekek's Avatar
The Ralliart mounts are similar to the OEM mounts in their design. They are a molded rubber with molded in steel inner sleeve and steel outer sleeve. Because of this they MUST be installed with a press. They are, in fact, only inserts. They are not complete "bolt-in" mounts, which would consist of the bushing and mount assembly. They are higher durometer than OEM and the rear mount is the only one where the design is actually different.
After installing the entire set I can say I love the feel during acceleration. However, I would NOT install these if you aren't a car guy and won't mind some decent vibration in the car. My dash and steering wheel both shake (stock cams, only TBE). Here is a link to a previous post I made with a couple pics.
https://www.evolutionm.net/forums/sh...+engine+mounts
The Powerflex bushings, as I understand them, are inserts made from polyurethane. They are solid poly and 2 pieces per insert with a slip in steel inner sleeve. Their installation is easier b/c you don't need a press to install the new inserts.
The performance benefit should be the same between the two items. I cannot comment on the cabin vibration of the Powerflex though since I have never seen a car with the whole set. Pricing I would imagine is about the same. Ralliart is around $189 shipped (for all 4) and based on the $50 for one cost of the Powerflex it's total set pricing will probably be the same ($50 x 4 = $200).
Old Feb 22, 2006 | 06:56 AM
Mike@Forge's Avatar
Here's the two links for all you need to know about the Powerflex bushings:
https://www.evolutionm.net/forums/sh...d.php?t=183514
2StepsAhead
Oct 23, 2008 02:50 PM
ItalyIX
Apr 10, 2007 08:14 PM
boostedwrx
88
Jun 17, 2006 06:09 PM
Mike@Forge
43
Mar 15, 2006 08:07 AM
nothere
Northwest Region
Dec 15, 2005 02:55 PM
