tighten the wastegate actuator?
Old Feb 23, 2006 | 08:33 AM
blakevo8's Avatar
ive been reading to eliminate some boost taper making the rod tighter on the wastegate actuator will help.
What is the downside to doing this does boost come on slower or anything like that, otherwise why wouldent it just come stock like that
Old Feb 23, 2006 | 08:58 AM
Warrtalon's Avatar
Don't mess with it, man. YOu keep asking so many crazy newbie questions. Just leave that stuff alone and do normal mods. Don't go crazy. The stock turbo naturally tapers, so just get an MBC to eliminate the factory ECU-controlled taper, then enjoy your newfound power. There's no way to fully eliminate all the taper due to the turbo's inefficiencies.
Old Feb 23, 2006 | 10:10 AM
zgodfathera's Avatar
good question but better answer~!
Old Feb 23, 2006 | 01:45 PM
Joey B's Avatar
Veteran: Air Force
So Warr -
The 4g63 that is on the Evo flows a hell of a lot more than the older 4g63 on the 1 & 2gs right? I remember that the original turbo with the 2g - the t2small (t-25)- did the same taper because the turbo ran out of breathe in the higher rpms.
Now there was a WGA offered for that turbo to stop that supossed very problem, just like forge offers something simular now for the stock EVO turbo. What I have a problem finding out is if there is anyone out there that tried it and did it work? Or is it that the turbo is so inefficient that if you could keep the WGA closed it would still taper off because it can't continue to make that same PSI with the volume of air at redline as it does in lower rpms. Some had said that at higher rpms the volume of air passing through was pushing open the WGA because the spring wasn't strong enough to hold it closed at higher rpms.
Do you know if this is what happens? Or what the hell is the damned truth?
EVO8LTW
30
Oct 29, 2018 03:17 AM
06rallyred
Sep 4, 2014 09:30 AM
ExtremeDSM
Apr 30, 2014 04:54 PM
blknblubkrdude
40
Apr 22, 2014 09:23 AM
russya
Jun 23, 2008 01:44 PM
