Wastegate actuator or boost controller?
Old Feb 26, 2006 | 10:26 AM
Billy17425's Avatar
OK, Which ones better for the evo and which one will make it so it doesnt taper off as much, cause i hate how much the power drops in the higher rpm range so how do i fix this?
Old Feb 26, 2006 | 10:35 AM
Warrtalon's Avatar
MBC. We don't do WGAs like SRT-4s or whatever else does those. The stock turbo will always taper boost at high rpm, so that's unavoidable, but with an MBC, the taper will be lessened. If you want more power up top, you need cams...
Old Feb 27, 2006 | 06:38 PM
wicked-won's Avatar
well if you plan on keeping the car why waste the hundred dollars on a manual controller when you can get a greddy profec and do things more safely and with much more controll you can keep the boost around 19 or 19.5 on the higher rpms i would suggest some more things for keeping your engine safe though
Old Feb 27, 2006 | 06:47 PM
4TUN8's Avatar
I completely disagree with this. IMO manual > electronic. Simplicity, cost, and MBC's are just as safe.
Old Feb 27, 2006 | 06:56 PM
2003lancerevo8's Avatar
Im running 500 horses at the wheels in my 03 evo 8 with a manual boost controller, I have had no issues with it in almost 2 years
Old Feb 27, 2006 | 07:01 PM
sivs's Avatar
yeah 2 me u pay for some pretty lights ILL sell u 10 LED lights 4 $400 if u want great deal
Old Feb 27, 2006 | 07:04 PM
fromWRXtoEVO's Avatar
MBC all the way. Remember, with the actuator you are set for one setting, with the MBC you have endless aplications, from cold nights to hot days adjustments, from low altitude to high altitude adjustments, from race gas to pump gas adjustments.
The MBC is the way to go.
Carlos
