Best Gas Stations for 91oct??
Originally Posted by TwStDeVo
which gas station has the best gas, Conoco, Shell, Chevron, Phillips 66 etc? i live in Nm, but will be tuned in Denver. please post your experience. thanks!
do a search on the vishnu forum you will find some results there.
Originally Posted by ROGERV
76 is the best 91 oct. in CALI.
Not all 91 gas is the same I learned that when to the Socal Dyno day (3/05/05) at Tunning Techlogies (TT) and got custom tunned by Shiv
I have a stage 1
HKS Exhaust
Helix DP
UR highflow cat
Fidanza Cam Gears
Walbro Fuel pump
K&N drop in filter
NGK Iriduim plugs
The last pull on Chevron (91) I made 284WHP and 290TQ
Chart1
I went back to TT 3/08/05 with 76 gas 91 and I made an avg of 298WHP/298TQ for three runs
Chart2
On 100 I made 324WHP and 311TQ.
The Gas I used in my case made a big difference. I am 76 fan now
maybe this helps ( this was posted by snoop)
I have a stage 1
HKS Exhaust
Helix DP
UR highflow cat
Fidanza Cam Gears
Walbro Fuel pump
K&N drop in filter
NGK Iriduim plugs
Chart1
Chart2
Originally Posted by cloudy
How about for AZ? I see you live in AZ. What do you use? I heard Texaco was good, but idk.
I was told by an Arco/BP rep that all gas is refined the same, it's just the amount and types of additives companies use that set them apart, interesting though, I may try 76 and see what the butt-dyno tells me
I highly doubt youll feel anything in the butt dyno, but maybe if you are trying to tune the car, you can squeeze an extra 10-20 hp out of it because of the better quality gas vs watered down CircleK/AM-PM stuff.
