My IX is just giving me ISSUES!!!
Old Mar 22, 2006 | 08:54 PM
  #61
--anonimuz's Avatar
My brakes sqeak!!
Old Mar 22, 2006 | 08:56 PM
  #62
SKILMATIC's Avatar
Thats actually normal because they are carbon brakes. They need to be warmed up to work properly. Now if you hear squeaking all the time then thats not usual.
Old Mar 22, 2006 | 09:02 PM
  #63
snowmants's Avatar
Originally Posted by parrothead
Have not heard the clunk yet. Of course, I'm still breaking it in (400 miles). My temp gauge on the cheesy intrument cluster "look like paste ons" isn't working. Didn't even notice it till I got home from picking it up. I have not had time to take back to the dealership to get fixed. And, what is the deal with the squeaky brakes? I never had them on the VIII. I guess these are all minor problems and stays that way.
It does work...I thought the same thing at first. It takes a few miles. Wait until you run it hard YOU WILL SEE IT HIT 90.
Old Mar 22, 2006 | 09:06 PM
  #64
fromWRXtoEVO's Avatar
K1S,
The 3 things I found wrong and anoying about my Evo 9 are:
1) Brakes make noise no matter what, even if you clen then periodically
2) gear shifting use to be notchy in just about any gear(went away with Shyncromesh)
3) the noise from the gearbox is annoying as hell, it sounds same as if you had straight cut gears(dog box)
That is all....
Carlos
Old Mar 22, 2006 | 09:10 PM
  #65
SKILMATIC's Avatar
I have a 9 and I havent experienced any of those problems. I am at 3000miles.
Old Mar 23, 2006 | 01:18 AM
  #66
S1monLM's Avatar
2 wks old
1500 miles
1st oil change at 1300 miles
Brake squeak big time!
Tranny clunk from 1-2-3-4
Otherwise.....I LOVE MY IX.....
Old Mar 27, 2006 | 08:42 PM
  #67
global909's Avatar
did u find out about the brakes squeling??? my IX has the same issue, im taking it in to have them look at it on wed...
Old Mar 27, 2006 | 09:09 PM
  #68
IXEvolutionIX's Avatar
My IX had the same problem with the brakes squeeling..but it went away. I called the dealer about it and they said it was probally just a pebble that got stuck in between the rotor and brake pad. My IX has that tranny thunk that eveybody is talkin about. Mine is a 5 speed though..
Old Mar 27, 2006 | 09:18 PM
  #69
Eggy's Avatar
wow you guys are really making the trannies sound like crap >.< this is scary...
Old Mar 28, 2006 | 12:59 PM
  #70
EVO-Lust-VIII's Avatar
Don't bother bringing it in... there isn't anything wrong. The brakes squeel... a lot of people have that problem (mine have since day 1). It's pretty normal with high-performance brakes.
Old Mar 28, 2006 | 01:21 PM
  #71
2forslashing's Avatar
I have almost 2000 miles on my MR and the 1-2 has been the demon on my tranny from day one, if I get the revs just right it slips in no problem.
I'm also dealing with noisy lifters which I hope in time with quiet down some.
Old Mar 28, 2006 | 03:48 PM
  #72
emagdnim8's Avatar
i only notice notchiness or a clunk from my 6spd when shifting high when the car is not warmed up...after its warmed up its like butta
Old Mar 28, 2006 | 05:38 PM
  #73
rodman's Avatar
What you people need to do is drive a DSM for awile, you will think your Evo is a Lexus after that
Old Mar 28, 2006 | 05:55 PM
  #74
mcwop23's Avatar
my brakes only squeak at low speeds like in parking lots
otherwise the only issue i've had is a loose boost solenoid fuse (i think). Oil changed at 1000 miles and 4000 miles. 5300 on the clock thus far.
Old Mar 28, 2006 | 05:58 PM
  #75
shivaswrath's Avatar
the tranny needs to be broken in, as do the brakes. . .the squeal is normal under light braking, the thunk is because you're dropping the clutch so damn fast and the flywheel hasn't bed to the clutch just yet.
the other stuff is cosmetic and you'll have to get used to it, it's STILL a lancer, you piad 30k for an engine and suspension that is WARRANTED, you could do the same to a stock Acura, Eclipse, Neon, etc. but you won't have the beauty of the R&D putting it together in such a seamless package that has so many little quibbling quirks. . .
the oil seal is odd, that's why I'd NEVER buy an early production run of a new model EVEN if it's 90% carried over from before. . .I've had my VIII for 8k since August of 2005 and no problems *knock on wood*. . . tranny change, btw, is recommended at 10 or 15k, not 4k, but people do it to keep the metallic grit from recirculating, which isn't an issue anyways because the drain plugs have magnets that pick up the synchro and lsd wear. . .so I'm not sure why we're wasting the money on tranny changes> . . . . ?
