PLX m300 installation- need help
Old Mar 5, 2006 | 10:13 AM
forbidden color's Avatar
I'm installing my plx m300 today.
all I have to do is ground it (black wire) and find a power source.
I was wondering if those who've done this already, which wires they used to do the power and where they've grounded.
I'm planning on grounding it on the left side of the steering wheel, where there is that bolt on the metal part.
I don't know where to do the power though. It says to use the ignition power wire.
I don't know which one that is and I don't know if that supplies more than 3 amp of power, consistantly.
Help will be... well, helpful.
lol
thanks.
Old Mar 5, 2006 | 10:22 AM
ray3328's Avatar
I use the RRE ECU diagram. Ignition pin is 82, chassis ground pin is 26. Good luck.
Old Mar 5, 2006 | 11:41 AM
you just hard wired it?
I'll do that.
You know, the plx m300 fits so perfect where the clock is. Only thing is that there isn't enough clearance on the back of it to have it flushed...
it's a shame....
Old Mar 5, 2006 | 01:06 PM
SSKILLA's Avatar
i used my cig lighter for power and i used the cars ground on the wiring harness,..i 4get what pin it is......
Old Mar 5, 2006 | 01:09 PM
pin 26 is the ground.
You can't just use the cig lighter ground for this? and power?
Do you know what color?
I pmed zeus and he told me the samething, to use the cig lighter wires.
Old Mar 5, 2006 | 01:25 PM
SSKILLA's Avatar
NO i used the cig power and the ecu harness ground
the cig power is a 12v power source that turn on whenever you turn your key so thats y i used it....very easy to get to
Old Mar 5, 2006 | 02:13 PM
is it the green wire?
i used that, plx is not lighting up.
for the ground, did you use pin 26 on the ecu wires?
Old Mar 5, 2006 | 02:27 PM
ok, not working.
i hate wiring.
need the ground on ecu and need to verify if the green wire coming out of the cig lighter is what I need...
I have the red wire from plx to green wire and black wire to the black with a bit of gold color wire on the ecu...
Old Mar 5, 2006 | 02:30 PM
SSKILLA's Avatar
look at the plug ...dont look at the wires from the plug to the cig ...look at the other side ...theres a red wire tap that one
Old Mar 5, 2006 | 02:31 PM
SSKILLA's Avatar
look at the diagram on the web of your ecu and find the ground....tap that one for ground
Old Mar 5, 2006 | 04:19 PM
mdesi's Avatar
Its really not that hard to ground it. The whole frame and all metal connecting to it is a ground. Get a self tapping screw and screw it down, or tap off one of your other gauges.
Good luck.
Old Mar 5, 2006 | 04:26 PM
That's how I usually ground things but it said to tap the ground wire, so I've tapped the ground wire.
Thanks by the way, I got it hooked up, it's working.
But now, I have another problem. p0117 code. I must of tapped one of the wrong wires and the car now wont start up... as soon as it starts up, the fan goes off.
DisgustipatedM3
Sep 4, 2013 08:54 PM
anthonyrb98
Apr 17, 2012 05:32 PM
gallas
Sep 5, 2010 05:08 AM
tboboy
Aug 7, 2010 03:39 PM
