Car runs like crap!
Old Mar 9, 2006 | 04:47 PM
Brembo350z's Avatar
Where do I get an obt2 code reader and how much are they? I'm scared to drive it anywhere!
Old Mar 9, 2006 | 04:54 PM
GTKage's Avatar
they vary in price and features, the cheapest one is around $40-$50
and u can buy those at autozone and similar stores.
Old Mar 9, 2006 | 04:57 PM
Brembo350z's Avatar
Ok, i'll go get one and see what it says. I can't imagine anything serious being wrong, i'm so confused with what it could be.
Old Mar 9, 2006 | 04:58 PM
4TUN8's Avatar
Check the engine bay for any harnesses unplugged.....I'm pretty confused.
Old Mar 9, 2006 | 05:02 PM
Brembo350z's Avatar
Ok, i'll check. I've already done a pretty thorough check! I did accidentally pull out one of the ecu plugs while the battery was still hooked up.
Old Mar 9, 2006 | 05:25 PM
f-dub's Avatar
I bet when you tapped the O2 sensor wires for your TT you did so incorrectly.
Old Mar 9, 2006 | 06:05 PM
mdesi's Avatar
^ +1 I was just going to mention that.
Try disconnecting the TT and reconnecting the o2 sensor. If your o2 sensor is not right your car will run horrible.
Old Mar 9, 2006 | 06:59 PM
Brembo350z's Avatar
My car was running fine with the TT installed though. I read the code and its P0203. Injector 3 is open. I'm guessing it's means it's wide open, that would be why my car is spitting out tons of unburned fuel.
Old Mar 10, 2006 | 04:44 AM
GTKage's Avatar
there u go, make sure to fix that exhaust leak as well, good luck.
Old Mar 10, 2006 | 04:50 AM
Jasil's Avatar
It runs poorly all the time? Idle, part throttle, full throttle? Take the EGT guage out and make sure all of the probe is still there.
Did you mess up the line going to the wastegate? If so you may have overboosted and hurt you're motor.
Good luck bring it to a shop interent diagnosing is hard.
Old Mar 10, 2006 | 05:04 AM
Ph3n1x's Avatar
I need some help. I recently installed an apexi turbo timer after which my car ran fine... Yesterday I recieved my defi BF gauges with V2 control unit. I installed the boost and EGT and now my car runs horribly! I can smell fuel coming out of the tail pipe along with a flow of white smoke... Does anyone know what could be the culprit of this? For the gauges I tapped 3 wires into the cig. lighter, and then for the power I tapped into a wire out of the ecu. This wire is pin # 80 and has a constant 12V source.
When I installed the TT i had to tap into 2 wires, one for the ground, one for the O2 sensor. Any help or tips would be greatly appreciated!
John
why didn't you just use the HKS Harness for the Turbo timer?
Old Mar 10, 2006 | 05:16 AM
8urv8's Avatar
I honestly have no idea what could have gone wrong. Run fine before you installed the gauges, now it doesn't. Did you make the connections to the right wires coming out of the ecu? Maybe you messed up one of the other wires coming out of the ecu. I got the smoke and the bad running once when I forgot to tighten one of the hose clamps on the intake and the pipe blew off. Just my thoughts.
Old Mar 10, 2006 | 05:25 AM
EvoRecordSetter's Avatar
lol, back track until your car runs good again.
Old Mar 10, 2006 | 12:10 PM
Brembo350z's Avatar
Thanks, that's the plan!!!
Old Mar 29, 2006 | 06:01 AM
i assume you figured it out now? what was the problem maybe we can archive this post for others.. might help?
