What the hell? My CEL turned off
Old Mar 9, 2006 | 05:29 PM
BushBurninEvo's Avatar
After driving around 40,000 miles with my CEL constantly being on, it suddenly turned off I'm so use to it that when it turned off this morning, I thought something was wrong with my car.
Old Mar 9, 2006 | 05:31 PM
brandonbigdog's Avatar
my car did the same thing, was on for like 5,000 miles and then just went off for like 3 days and then came back on again!
alloyic_rs's Avatar
you mean your CEL caused by your test pipe or somethin else?
Old Mar 9, 2006 | 05:32 PM
high flow cat
Old Mar 9, 2006 | 05:35 PM
forbidden color's Avatar
your code hasn't happened since last 40 cycles, which means you start your car, turned your car 40 times or so (standard is 40 cycles, mitsu, I don't know the specifics) without that code happening again.
This only happens, ex: you had p0300 code cel light on, but for the next xx cycles the p0300 didn't happen (mis-fire). So the cel light turns off.
eh...
Old Mar 9, 2006 | 05:36 PM
alloyic_rs's Avatar
put some antifoulers (extension) on your o2 sensor, that way you can run your high flow cat or test pipe wihout the CEL
Old Mar 9, 2006 | 05:50 PM
mdesi's Avatar
turn your key to the on position and make sure the bulb didnt blow. After 40k it might have.
Just another guess.
Old Mar 9, 2006 | 05:52 PM
Rnm's Avatar
Rnm
I've had that happen. I blew off one of my intercooler clamps and got a code and I didn't bother resetting the ECU or disconnecting the battery. The next morning, my CEL was gone, but it was still stored in memory.
Old Mar 9, 2006 | 07:46 PM
Just another guess.
That might be the case. I'm going to see in a second.
