My dyno numbers
Old Mar 16, 2006 | 06:53 AM
  #31
Evo VIII 4G63's Avatar
because it was a package deal, they came with the cams.
Old Mar 16, 2006 | 07:41 AM
  #32
Jeff_Jeske's Avatar
Originally Posted by Evo VIII 4G63
I installed a aem uego wideband last night and my air fuels are 10.0 at wot in every gear.
sean ivey tuned my car
Well....something isn't right. I would call Sean and see what he thinks is going on.
Old Mar 16, 2006 | 07:58 AM
  #33
evozakk's Avatar
id have to say the 24 psi is what is doing it
Old Mar 16, 2006 | 10:25 AM
  #34
going to do boost leak test now, so the resultsof that will be in later tonight.
Old Mar 16, 2006 | 11:22 AM
  #35
xbbevo's Avatar
great numbers!
Old Mar 16, 2006 | 12:18 PM
  #36
sivs's Avatar
alright the leak test was done to his car and it leaks down from 15psi-0 in about 5 min or so. There was a bov leak but that was fixed. No major leaks after that.
Old Mar 16, 2006 | 01:19 PM
  #37
sivs's Avatar
ok the aem uego is still reading 10.0 why is it so rich at wot
Old Mar 16, 2006 | 02:16 PM
  #38
Jeff_Jeske's Avatar
That leak down is pretty good. I wouldn't worry about a leak.
The AFR .....well I would try to get another reading from another souce. You dont want to pull fuel out and then find out the WB is bad and you have been running your car too lean.
Old Mar 16, 2006 | 03:06 PM
  #39
jbergmeier's Avatar
considering the dyno reads low, i would say those numbers are pretty good
Old Mar 16, 2006 | 04:22 PM
  #40
well after the leak test we took the car and the a/f's improved a little to 11.1 -10.9 but all of sudden they dropped back down below 10.0
Old Mar 16, 2006 | 04:38 PM
  #41
steelcityevo8's Avatar
what was ur a/f ratios when u got it tuned ?? was it tuned on a dyno ? did they have wideband at the dyno??
Old Mar 16, 2006 | 07:51 PM
  #42
i dont know what the air fuels were when it was tuned. It was done on a mustang dyno, with ecutech flash.
Old Mar 16, 2006 | 09:38 PM
  #43
Sean@Iveytune's Avatar
Call me up and let's see what's going on here, sounds very odd. 10.9-11.1 isn't nearly super rich but to cut a long story short, call me up, I am willing to put it back on the dyno and check to see if everything is ok.
Sean
Old Mar 17, 2006 | 02:13 PM
  #44
evoate ya's Avatar
Their dyno reads low in comparison to dynojets. Sean tuned my AEM ems on that mustang and the car put down just shy of 385 whp. I was on a dynojet a couple of weeks before and made 440 whp, and my car pulled noticeablly harder after Sean's tune than my previous one. The enviromental conditions were very similar, about 3 degrees differance.With that being said, you really shouldn't base your cars performance off of the dyno #s, its just a tool for tuning.
I think you might have something wrong with your Wideband, a friend of mine has a AEM uego and it is always causing problems. 10 to 1 a/f is the richest value the meter will show. I would troubleshoot the wideband setup if I were you. Either way Sean is a great guy so Im sure if anything is off he will get you where you need to be.
Old Mar 17, 2006 | 02:42 PM
  #45
Jeff_Jeske's Avatar
That's what I was saying.
For the record....using standard Vishnu maps on my car on the mustang dyno with tailpipe sniffer provided me with an overall 11.8:1 AFR. I added some fuel in a couple spots specifically peak torque where it went in to the 12s but my ending final tune was 11.5-11:8 to 1 AFRs on 93 octane. My boost peaks to 22PSI and fades to 16PSI at rev limiter. That boost fade is nothing more than the turbo running out of breath and not being able to supply the motor with air. Prior to cams I could hold 21-22 to redline.
