Very interesting discovery
Old Mar 20, 2006 | 08:03 PM
fromWRXtoEVO's Avatar
Originally Posted by Killboy
My '05 Evo (standard model, no SSL package) does NOT have those "fins". I thought it was just an MR/aluminum roof thing...
BINGO!!! Mystery solved.
Summary:
The bumps on the side of the roof were only made on the aluminium roof on the 2005 Evo 8 RS and MR and perhaps the Evo 9 RS and MR as well. I am happy that I learned something new today
Thanks guys!
Carlos
Old Mar 22, 2006 | 03:33 PM
trinydex's Avatar
Originally Posted by fromWRXtoEVO
no $hit.... for real?, WOW, I just learn something new today(I am not being sarcastic). So is it for stability in conjunction with the vortex?
Thanks!
Carlos
no that is totally wrong. ti's there for the expansion, steel expands at a different rate than aluminum when heated. the ridges are there so that the aluminum won't out expand the steel and then pop itself out of the spot crimps.
Old Mar 22, 2006 | 03:45 PM
Killboy's Avatar
Wow you sound so confident, like a Mitsubishi engineer or something. Do you have a source for that info?
It's not that I doubt it so much, just that I think a LOT of people on forums tend to spout personal theories as concrete fact.
Old Mar 22, 2006 | 03:50 PM
Karma'sEvo's Avatar
Summary:
Thanks guys!
Carlos
carlos i know for sure the 9rs has the aluminum roof.. cause as you know i have one..
Old Mar 22, 2006 | 04:47 PM
12mnkys's Avatar
well i have an 88 chevy...what of it?!?!
karma you are as lut...and carlos i don't have the ridges on my 05 so I think its an aluminum roof thing!!!!
-cheers-
Old Mar 22, 2006 | 04:53 PM
donmeca2020's Avatar
i have an 05 evo 8 also i dont believe i have those. then again i might just have to check tomorrow when i get some light.
Old Mar 22, 2006 | 06:34 PM
Evo_Jay's Avatar
Damn again..
03-06 GSR (With or Without SSL) - steel roof
04-06 RS - Aluminum roof
05-06 MR - Aluminum roof
Aluminum roof weights 8.8 lbs less then the steel roof. It lowers the center of gravity 50mm without lowering the roof.
Old Mar 22, 2006 | 08:17 PM
hondafan's Avatar
it's standard for an aluminum roof to make it stronger. have you ever held a big square piece of thin aluminum? it's very flimsy. now put it in a brake and put 2 bends in it. not so flimsy anymore. they have nothing to do with aerodynamics, just to strenghten the metal.
Old Mar 22, 2006 | 11:55 PM
trinydex's Avatar
you people totally don't know how to read. I ALREADY SAID WHAT THE ****ING REASON IS.
it's NOT FOR THE STRENGTH IT'S NOT FOR THE AERODYNAMICS
it's to allow for the expansion of the metals. aluminum expands about TWICE as fast as steel... this would require them to make the aluminum roof TWICE as thick if they did not somehow make an innovation to COMPENSATE FOR THE EXPANSION.
you also can't WELD aluminum and steel together which is why i stated that they used SPOT CRIMPS. how do i know this? BEST MOTORING VIDEO WHERE THEY SHOW HOW TEHY PUT THE ****ING ROOF IN.
STOP ****ING SPECUALATING I ALREADY TOLD YOU THE REASON.
you people are like talkin' about purple hippos and how they make you feel warm and fuzzy inside and you're totally pulling it outta yer ***.
Old Mar 22, 2006 | 11:58 PM
Killboy's Avatar
And without some source, your opinion is no more factual than anyone else's.
Settle down Beavis.
Old Mar 23, 2006 | 12:07 AM
trinydex's Avatar
damn you don't know how to read etiher... it's the best motoring international comparing the mr and the gsr. it's OLD. they have some gymkana guy drive the nuts off it and then they throw a big rubber mat on the roof to test the difference again.
Old Mar 23, 2006 | 12:10 AM
vtsnake's Avatar
Okay trinydex, is almost right but not quite. He is definitely right tho that people speculate things around here as if they are truths...
anyway here is a quote...
"Mitsubishi engineers overcome the difficulty of joining an aluminum roof panel to a steel monocoque body by developing a technique using self-piercing rivets (SPR) and structural adhesives.
The SPR is a structural rivet with a partially hollow shaft that allows it to pierce through the panel without pre-drilling any hole. After piercing the panel, the SPR expands radially into the structural member below. Introducing two longitudinal design beads in the roof panel solved the problem of thermal warping during the paint process, caused by aluminum having a thermal expansion nearly double that of steel. These beads also serve as an eye-catching design element."
from this link (a little past half way down, under weight reduction)
LINK
Old Mar 23, 2006 | 12:37 AM
Killboy's Avatar
Excellent find, thanks vtsnake!
LINK
Old Mar 23, 2006 | 12:43 AM
vtsnake's Avatar
anything for our fellow evom nooooooobeeeesssss!
Old Mar 23, 2006 | 01:30 AM
RA111424's Avatar
interesting info guys. i never noticed that either carlos. good to know
