spark plug non foulers
Old Mar 21, 2006 | 05:58 PM
stikillller's Avatar
i went to pep boys, autozone, and r & s strauss.......none of them had the 18mm......should i try the 14mm????
Old Mar 21, 2006 | 06:09 PM
h22gordo's Avatar
I did a search, and came up with this thread. Same thread I referred to when I made my o2 simulator fix. It says 18mm
https://www.evolutionm.net/forums/sh...ight=simulator
Old Mar 21, 2006 | 06:15 PM
yes i know but i thought i read somewhere that someone used 14mm because they couldn't get 18mm ....... just trying to see if others did the same
Old Mar 21, 2006 | 06:46 PM
honda-guy's Avatar
i just bought a set from autozone a couple of days ago, it comes in a pack of 2. i can't see how the 14mm is going to work since you would not be able to screw the 02 sensor on to it.
Old Mar 21, 2006 | 06:58 PM
Lancematic's Avatar
I work at pepboys. We have them in Berlin NJ next to Atco raceway, and I know Marlton on rt 70 has them also. If you want I can get the part number and check the inventory in Penns landing or ne where else if you want. Just pm me if you want me to check for you.
Old Mar 21, 2006 | 07:27 PM
Jeller's Avatar
On my previous car I used on long one and one short one, only drilled the longer one that the o2 went into and it worked fine.
Jeller
Old Mar 22, 2006 | 03:55 AM
AUSS1E's Avatar
short ones worked for me just fine
Old Mar 22, 2006 | 04:20 AM
honda-guy's Avatar
Jeller
i'm just going to try to use one first and see if how it works then try two if needed. i have a high flow cat and only get a CEL once in a while, usually when it's cool out side.
Old Mar 22, 2006 | 03:24 PM
trinydex's Avatar
exactly... you can't screw it in... hence doesn't work.
Old Mar 24, 2006 | 08:26 AM
got it after going to 5 different place!! 18 mm!! yessssssss now all i need is a drill -.-
Old Mar 24, 2006 | 08:33 AM
nbpal4000's Avatar
-_-;;
Old Mar 24, 2006 | 02:06 PM
trinydex's Avatar
you should have bought the drill bit while you were there.
