WTF.... Fuel Gauge is acting up
Old May 17, 2007 | 09:20 AM
pac74's Avatar
i'm going to the junk yard and try to fing another unit for my problem. My gauge dont work at all. good luck with yours.
Old May 17, 2007 | 09:26 AM
Obi Juan's Avatar
I bet mitsu will tell him he used a high performance fuel so it has voided the warranty.
Old May 17, 2007 | 09:29 AM
precisi0n's Avatar
my gauge acts up all the time. I just deal with it... it will read a half a tank one minute and 3/4 the next... very weird
Old May 17, 2007 | 09:51 AM
VictoryEVO's Avatar
Couple of causes.... fuel level sensor in tank... electrical short from tank to ECU..... or ECU function itself. Its def warranty if you do not have any fuel upgrades. A scan tool gauge sweep a couple of minutes with a DVOM will find the problem.
Old May 23, 2007 | 08:19 PM
STOCK_EVOLUTION's Avatar
i just had this happen to me like 10 min. ago! I was almost on empty so i went to 76 and pumped $20. So I i get back in my car start it up and start driving. about 1 min into driving i noticed the gauge had the same reading as before i pumped the gas! so i go back to the gas station thinking i didnt pump any gas but it showed i had pumped 5.xxx gal. so on my way home it started to creep up to a little over half. This freaked me out!!
Old May 23, 2007 | 08:40 PM
Ph3n1x's Avatar
Can happen if you dont turn the car off when ur filling up.
Old May 23, 2007 | 08:50 PM
karlzhot's Avatar
This happened to me a week ago. My car was alittle less then 1/4 tank. Put about 20 bucks in and when i started up it was still reading the same. Took about 5-10 miles before it read where it was supposed to. Weird because it's the only time it's ever done it. Maybe bad gas?
Old May 23, 2007 | 09:42 PM
urslo4n8's Avatar
Just a ****ty sending/float unit thats all. We all deal with it.......but if its that off i would pull the pump and inspect the float, maybe its bent
