EVO IX 20G question
Old Mar 29, 2006 | 08:54 AM
J8dailo's Avatar
EVO IX 20G question
I always thought that the evo 9 20g turbo bolts right on into an evo 8... but whats this installation kit i been hearing about??!? i know that the outlet pipe is different between 8 and 9 but whats this installation kit for 20G buschur sells is about???
Old Mar 29, 2006 | 08:57 AM
MitsuEvoIIX's Avatar
you need all the coolant and oil lines in order to fit it on the 8. The oil lines and coolant lines from the 8 and 9 are not the same...also you need the piece to fit to the LICP
Old Mar 29, 2006 | 08:59 AM
J8dailo's Avatar
so the kit that buschur sells is required??
is there any turbo i can get mounted up to stock location with no modification???
Old Mar 29, 2006 | 09:00 AM
J8dailo's Avatar
and any other place sells kits for 20G because the one buschur sells is $270.. i think its a little pricey
Old Mar 29, 2006 | 09:03 AM
superman105's Avatar
I have a new 20G-8 for sell
Old Mar 29, 2006 | 09:17 AM
bigfishs's Avatar
Seems to me like if you are going to the expense and bother of putting a bigger turbo onto your car, 200 odd bucks is reasonable. Bushur stuff is normally pretty reasonably priced. Did you try contacting them and asking them?
Old Mar 29, 2006 | 09:36 AM
Warrtalon's Avatar
Yes, there are plenty of stock replacement turbos you can get that require no kits, but if you want to upgrade to any IX turbo, you need the new outlet pipe, and you need the new coolant/oil lines. The kit is just OEM Mitsu parts that Dave had to buy from Mitsu so that he could provide customers with the necessary parts, otherwise he'd be selling a turbo that none of you could use until you went to Mitsu yourself and bought them. If you want a IX turbo on your VIII, you need these parts. Dave isn't selling them for profit - he's just adding them so that you can bolt up your new turbo.
Old Mar 29, 2006 | 09:43 AM
deadbeatrec's Avatar
correction, the new outlet pipe only fits with there intercooler, DOESNT FIT WITH THE STOCK INTERCOOLER. thought i would clear that up. so bascily u need the oil coolent lines.
Old Mar 29, 2006 | 09:44 AM
J8dailo's Avatar
thanks.. i think i'll be getting evo 8 20G turbo.. it should fit with no mods
Old Mar 29, 2006 | 09:51 AM
WannaRace's Avatar
Okay so one more thing...with a stock intercooler/LICP solution this turbo will bolt up right?
Old Mar 29, 2006 | 04:01 PM
k.lowe's Avatar
warr you changed your sig....
Old Mar 29, 2006 | 04:03 PM
Warrtalon's Avatar
I was runnin' out of room.
Deadbeatrec, thanks for the clarification. You still need an outlet pipe that fits the IX turbo unless it already comes with the turbo.
Old Mar 29, 2006 | 04:06 PM
J8dailo's Avatar
thanks warr, i decided to get evo ix 20G and as far as the install kit.. it consists of 4 pieces, turbo outlet pipe, oil return line and 2 water line which are cheaper from the dealership than buschur.. thanks though
Old Mar 29, 2006 | 06:36 PM
Nad1370's Avatar
For the 20g-9 turbo....
It would be cheapest if you just used the stock 8 lines.
With some creative bending....they will fit.
Also the lower stock 8 pipe will fit.
You just have to move the + cable on the starter to a 5 o'clock position from it's 12 o'clock originally so the lower pipe won't come in contact with it.
It would probably add another 30 min. on the job to make this work but in the end.
You'll be glad you save yourself some $$.
But it's your choice if you still want to order the install kit .
Old Mar 29, 2006 | 10:54 PM
Evo Police's Avatar
Just for clarification. Someone like myself who has already upgraded there intercooler will just need to buy the installation kit with the IX-20G and that's all I will need for the install?
