I need a mod for under $500
Old Apr 2, 2006 | 10:30 PM
KY's Avatar
KY
Here is the deal. Al is supposed to be coming to Atlanta in May.
I currently have: Buschur intake, Forge UNOS, ebay TBE and base flash.
I want to get something done for around $500 (installed for free by myself) so I can have to car re-flashed in May with the new mods. I will be adding a fuel pump regardless.
I was considering porting and coating the stock manifold and outlet and maybe getting a 10.5 hotside. Maybe even getting an alky/meth kit.
I am trying to get another 30whp out of her. Should I hurry up and get something or wait and maybe get a bigger turbo or something?
I know this is kinda broad, but I am just looking for some ideas. Thanks
Old Apr 2, 2006 | 10:33 PM
scorke's Avatar
Whats your end goal for your car, what are you looking to accomplish now, what do you use your car for?
Scorke
sirloin1219's Avatar
cams?
Old Apr 2, 2006 | 10:37 PM
fraser91084's Avatar
i'd say a walbro fuel pump, boost controler set to 20 or so, and a reflash
Old Apr 2, 2006 | 10:40 PM
KY's Avatar
KY
You just named waht I have minus the fuel pump that I already said I am going to get.
My end goal is probably mid to high 300's.
I would get cams, but I can't(don't want to) install myself and that is about $300 in labor.
Old Apr 2, 2006 | 10:42 PM
jmartinez1170's Avatar
i say save it until you get what you really want.
Old Apr 2, 2006 | 10:52 PM
KY's Avatar
KY
You are right. I think I am just going to save and do cams. Is the manifold, housing and outlet really worth the money and time for the gains? Should I just get a cheap set off of ebay (manifold and outlet combo)?
Old Apr 2, 2006 | 11:01 PM
4WS Tuning's Avatar
alky kit.....
Old Apr 2, 2006 | 11:06 PM
SKILMATIC's Avatar
Yeah dont worry you will find it that alot of people dont read here.
I would go with what martinez said and wait till you really know what you want then make the decision.
Old Apr 2, 2006 | 11:33 PM
EvoRobert's Avatar
+1. Save it for a rainy day or like you said for the cams
Old Apr 2, 2006 | 11:40 PM
mrmefodman's Avatar
A set of comp cam 280''s
Old Apr 3, 2006 | 12:04 AM
elhalisf's Avatar
port the exhaust manifold- $75
10.5T housing- $250
tubular O2 housing- $90
Horsepower gains- 30 whp
moreover, i dont think you will need a reflash for those mods.
Old Apr 3, 2006 | 01:07 PM
dsmfan95's Avatar
I would get a decent blow off valve. I bought my cams and had them installed for under $500.
Old Apr 3, 2006 | 01:10 PM
Fluid1's Avatar
I'd get the Buschur o2 housing, jet coated, and the exhaust manifold ported and jet coated by Buschur. That should be close to the $ you want to spend. If you want to do it right, also get the 10.5 hotside ported and coated, too.
Old Apr 3, 2006 | 01:18 PM
GPTourer's Avatar
I say save up and get cams. There's no other mods in between a full turbo upgrade that will give you any appreciable gain over what you already have.
