Will racegas make more power even without being tuned for it?
Old Apr 6, 2006 | 09:17 AM
Sap12687's Avatar
Question Will racegas make more power even without being tuned for it?
Sorry for the awkward wording of the title i just dont know how else to put it. Im in a heated argument with a friend of mine who says that if i put 116 in a car not tuned for 116 it will not make any more power at all. Is this true? Do i have to have a race gas map to see any benefits at all?
Old Apr 6, 2006 | 09:19 AM
NoTec's Avatar
Depends on the temp outsifde but it will make more power if your car is currently knocking from regular 93 you have up there in NH.
Old Apr 6, 2006 | 09:20 AM
Warrtalon's Avatar
Yes, it will not make more power if you put in leaded 116. In fact, you will probably LOSE power by running so rich due to the high octane leaded gas.
Now, that first answer was in a vaccuum assuming you don't raise the boost and that you aren't already operating in a manner that is causing knock due to running too much boost or running on the ragged edge of lean with a lot of timing. If you are losing power on pump gas due to these conditions, then some higher octane would provide an increase. If your pump gas tune and boost levels are all in good shape, though, then you'll lose power from going quite rich.
You can add race gas and turn up the boost to gaine 20-30whp without a retune, but that's most recommended with low octane unleaded fuel (100-104oct). I wouldn't be messing with 116oct unless I had a way to retune for it...
Old Apr 6, 2006 | 09:21 AM
Sap12687's Avatar
I sure it has to do with more than just the temperature outside. As far as i know the 93 up here is still better then the 91 people are forced to use elsewhere.
Old Apr 6, 2006 | 09:24 AM
Sap12687's Avatar
Awesome Warr. All you anti-warr people please take note.
Mods feel free to remove this thread.
Old Apr 6, 2006 | 10:15 AM
Drunken MOnkey's Avatar
isnt 116 leaded? or is there one more level of gas above that.
Carlo
Old Apr 6, 2006 | 10:19 AM
Warrtalon's Avatar
It's definitely leaded as I already mentioned.
Old Apr 6, 2006 | 10:21 AM
TxEvo8's Avatar
That's pretty funny
Old Apr 6, 2006 | 10:25 AM
Juiced's Avatar
Carlo
Yeah VP import is rated at 120+
NoTec's Avatar
After running my car in the heat of a CT summer, my cars used to ping quite a lot. But when conditions got better/cooler, no more knock. Higher octane would have helped. But Warr brings up good point about going with to high an octain and running rich.
Old Apr 6, 2006 | 10:26 AM
whoops didnt read that. on a another note. that leaded 116 aint no joke. friend put it on a open downpipe no o2 sensors sti tuned for 116 with xede, and thats it. it was STUPID FAST!
Carlo
Old Apr 6, 2006 | 10:30 AM
djh's Avatar
djh
Why do people assume that's true? Let's take a look at Sunoco's specs:
100 sp.gr. 0.764 (GT100 unleaded)
110 sp.gr. 0.725
112 sp.gr. 0.715
116 sp.gr. 0.700
Pump gas varies widely but is in the range 0.72 to 0.77. In this case the C16 definately has a lower specific gravity than pump gas. Since fuel injection is volume based a less dense fuel results in a leaner mixture.
Dave
Old Apr 6, 2006 | 10:33 AM
zgodfathera's Avatar
sorry dont mean to thread jack but if u put octane booster in ur gas tank would that affect the car in anyway? say if u did it everythime u filled up? 91 craptane!
Old Apr 6, 2006 | 10:38 AM
Warrtalon's Avatar
Don't use octane booster.
Dave, I don't know those numbers, but it's common knowledge that you go immediately richer on leaded race gas. You don't go leaner, however you can obviously retune the car to a much leaner state than on pump gas.
Old Apr 6, 2006 | 10:42 AM
hey War is there any specific reason why not to use octane booster?
