Service engine light
Old Apr 9, 2006 | 08:50 PM
WEVO's Avatar
I went to an auto x event yesturday, and I realized that my profec b boost setting was much higher than it should this morning, maybe someone have touched it by accident since it's mounted on the lower console of the dash board. Then, my service engine light came on this afternoon, however, my car drives and sounds fine, so what's wrong with my car, could I have damaged my engine and turbo already? please help, I'm getting really nervous!!!!!!!!
Old Apr 9, 2006 | 11:36 PM
3K's Avatar
3K
Get the code read with an OBDll scanner. I have a feeling that it's probably a PO401.
Old Apr 9, 2006 | 11:56 PM
WEVO's Avatar
What does EGR Flow Insufficient Detected mean?
Old Apr 10, 2006 | 12:11 AM
3K's Avatar
3K
Is that what code you got from the scanner? Here's a link to help you.https://www.evolutionm.net/forums/sh...ighlight=po401 I'm not saying that is the code you have, but to me it sounds like it.
Old Apr 10, 2006 | 02:12 AM
WEVO's Avatar
From the link it says CEL, but it says SERVICE ENGINE LIGHT instead. Can the OBDll scanner pull out the codes for SERVICE ENGINE LIGHT as well? Thanks.
Old Apr 10, 2006 | 02:19 AM
Chewie4299's Avatar
CEL = Check Engine Light = SES = Service Engine Soon = Whatever the light that says your engine is fuggin up says lol
My CEL never came on in my old lancer but i had a problem with the EGR twice. Try running some fuel system cleaner through the car. I did it once and never had the problem again. Probably something gunked up.
Old Apr 11, 2006 | 01:18 PM
WEVO's Avatar
I went to auto zone to pull the code and indeed it was P0401, I guess I'll just reconnect the plug, if I can find where it is.
Old Apr 11, 2006 | 02:40 PM
Tonz of fun's Avatar
I just signed up like two days ago and i think this guy is Genius!!!!!!!!!!!
