anyone pay to have gauges installed?
Originally Posted by Pikachu
Besides the oil filter housing (IMO not the best place to put it because 1. it sticks out quite a bit onto the engine housing cover. 2. It gets cload up with grim very fast). There is the original oil pressure switch from the factory location. All is needed is a T-joint. I think its good to put aftermarket oil pressure sensor as near to the OEM ones.....
I worded that wrong, I WOULD tap into (tee into) the OEM switch or the block for an accurate reading.
Good luck reaching that stock one... From what I've read it's under the #1 intake runner, which means it's low on the back of the block. I tapped mine down by the filter and I read about 110psi or so at WOT, and about 18 or so at idle. I'm pretty sure it'll get gunked up (my oil filter is brown by the time it needs changing) but the wires have loom on them. If it gets too bad I'll just cover the sensor up with something.
Originally Posted by stikillller
boost, oil pressure, oil temp, and control unit = 500 install ???????? anyone else think this is sounds right?
i also thought that some gauges are a little bit more "hands on" right? so it would be alot harder to install for a normal person like myself? damn i really want to have these installed but the a very reputable tuner shop here on the eastcoast told me either 500 or 600 for the install and it would take allllllllll day. damn! i don't have all day, and no i can't take off [i run my own busness]. What can i do guys?
I'm speechless.....USD60 for the hour.......
Thank goodness in Singapore its still by the per job basis regardless of the number of hours......
60 dollars never seemed to be that much money...
i think for a reputable place the labor/hr is more along the lines of 65-70/hr right?? gosh, im just going to pay and have a boost and oil pressure gauge installed for the time being, i mean i only have a tbe, filter, and going to get a flash and mbc. i should be ok......right? i hope so!
Originally Posted by evozakk
I'm pretty sure you have to tap into the block for the oil pressure. That could be the hardest out of the three.
Originally Posted by evo 8 ya
NO don't do that. Greddy sells a adapter block that you can screw oil temp and oil pressure sensors into. It's a very nice piece that goes in between the oil filter and oil filter housing.
link please? this will cut the installation time to a little less correct?
here is the link
http://z1auto.com/prodmore.asp?model...ne&prodid=1142
