Help with clutch ASAP
Old Apr 20, 2006 | 08:07 AM
Gonzo0991's Avatar
hey guys,
this morning i adjusted my clutch (used to be extremely high up) by following the steps on evomoto. after i tightened everything up i tried to turn on the car and nothing happened, i can hear the starter "click" but the car doesnt turn on. i tried to adjust it again and put it back to where it use to be but it still wont turn on.
any help would be appreciated
thanks
gonzalo
Old Apr 20, 2006 | 08:16 AM
Compjoc's Avatar
did you bend the clutch peddle sensor?
Old Apr 20, 2006 | 08:19 AM
Gonzo0991's Avatar
i bent it a little bit to fit the wrench in there
Old Apr 20, 2006 | 08:21 AM
fsugatorbait's Avatar
Well that sounds like your problem. You are going to need to bend it back. See if you can press it down completely with something and try to start the car.
Old Apr 20, 2006 | 08:41 AM
Gonzo0991's Avatar
fixed it, i just bent back the sensor and made it so that it would come in contact with the "pad" on the clutch
thanks for the help guys
